Go Back   Automotive Forums .com Car Chat > Nissan > Primera | G20 > Suspension
Suspension setups, shocks, springs, tires, handling.
Old 11-07-2001, 12:01 PM   #1
Trag
Coil Overs
Does anyone have pics of there coil overs for a P11 or where i can see a picture of how they look? Also what other bramds make coil overs...
jeff
Trag is offline   Reply With Quote
Old 11-07-2001, 12:48 PM   #2
Mrcoilover
Re: Coil Overs
Their are the Tein's,B&G,JIC. You can check out the thread called B&G install, and see what they look like and how low they go. Tein's, you can check their website. For the B&G, youll have to go 2 like page 2 of the suspension thread, a little old.
*Mod List*
2 JL audio W3 12's
Rocksford Fosgate 600w amp
Tein type NA (1.7)
Nokya Arctic purple headlight bulbs
Rims coming soon...
"I always ride dropped, how bout you?":finger4:
Mrcoilover is offline   Reply With Quote
Old 11-07-2001, 03:26 PM   #3
AznVirus
AznVirus's Avatar
Send a message via AIM to AznVirus
dont forget ground control
1.6 - The Underdog
GA16DE-T Club!
AznVirus is offline   Reply With Quote
Old 11-07-2001, 03:31 PM   #4
Mrcoilover
Oh yeah. Can't forget them, but then again, no shocks to go with them. I am 100% against mixing and matching. Not trying to waste money up in here.
*Mod List*
2 JL audio W3 12's
Tein type NA (1.7)
Rims coming soon...
Old 11-07-2001, 10:34 PM   #5
P10DET
P10DET's Avatar
I don't mean to be rude, but you are totally misleading people with these statements. Mixing and matching? Coilovers are designed for using different springs. Mixing spring and damper companies is a non-issue as well. The only downside to the GCs is that they are not permanently attached to the damper body. Then again, for those of us racing in the SCCA's IT category, they are a Godsend.
If I could buy proper threaded body damper coilovers of good quality, I'd rather have them than the threaded sleeves of the GCs, but there are some excellent dampers out there (such as Koni and Bilstien and others) that I would rather use with the GCs than so-so coilovers.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
P10DET is offline   Reply With Quote
Old 11-08-2001, 03:26 AM   #6
G22DET
G22DET's Avatar
Send a message via ICQ to G22DET Send a message via AIM to G22DET
a coilover set up uses custom springs with custom spring rates that allows you to switch between different settings. the coilover springs are also designed differently than conventional springs (a lot smaller than conventional, lowering springs.) it doesnt hurt to "mix and match" different coilover springs as long as you know what settings you wanna get and balance the front and the rear.
i guess generally speaking, if one particular brand offers springs and shocks, it's probably best to get that set such as in the TEIN case for the P11. BTW, you are confusing the TEINs with the term "coilover" the TEINs is a suspension system that's composed of lowering springs and adjustable shocks, NOT a coilover system.
From my knowledge, only Ohlin and JIC makes full coilovers complete with pillowball mount. the B&Gs do not come with the pillowball mount i believe.
Luke C.
GDA Power!
G22DET is offline   Reply With Quote
Old 11-08-2001, 09:26 AM   #7
Mrcoilover
I think you are misunderstanding me. See, you are straight b/c you have a P10. They have a strut set-up for those. I on the other hand have a P11. Now with that said, someone had got some springs and bought some 95 maxima rears and said it rose the back of their car up. I have nothing bad to say about GC's. Its the fact that right now, at this present time, nobody makes struts for P11's. That is why I'm staying away with mixing and matching "struts"! :smoka:
keyword: struts
*Mod List*
2 JL audio W3 12's
Tein type NA (1.7)
Rims coming soon...
Old 11-08-2001, 06:19 PM   #8
P10DET
P10DET's Avatar
keyword: struts
That's good. Because the P11 doesn't use struts.
But, I understand now what you were saying about using Maximum dampers (shocks). OTOH, Donster has Konis on his P11 and they are sweet. I've seen his car and I guarantee you it isn't raised up anywhere. It's a sweet car.
George Roffe
Houston, Texas USA
00 328i
Old 11-09-2001, 10:31 AM   #9
Mrcoilover
Smart ass! Shocks/struts. You know what I mean. Jackass! j/k. He has the Koni fronts and 95 maxima rears? With what springs.
*Mod List*
2 JL audio W3 12's
Tein type NA (1.7)
Rims coming soon...
Old 11-09-2001, 04:17 PM   #10
P10DET
P10DET's Avatar
Smart ass!
That's me.
Yes I do. That's why I said so. So, perhaps one insult was enough.
I think he has Ground Controls.
Don?
George Roffe
Houston, Texas USA
00 328i
Old 11-09-2001, 04:22 PM   #11
Mrcoilover
That's me.
Don?
Sorry! I guess one insult was enough. What kind of suspension do you have. I bet the ground controls are pretty bouncy aren't they?.:silly2:
*Mod List*
2 JL audio W3 12's
Tein type NA (1.7)
Rims coming soon...
Old 11-10-2001, 10:23 AM   #12
P10DET
P10DET's Avatar
Not when combined with the correct spring choice and the correct dampers. Mine is pretty sweet.
BTW, you always have to select the spring rates for coilovers. That is the beauty of coilovers. They use a standard size spring allowing for extremely easy change of rates.
George Roffe
Houston, Texas USA
00 328i
Old 11-11-2001, 09:32 PM   #13
b-b00gie
Banned
b-b00gie's Avatar
Send a message via AIM to b-b00gie
Just wondering...
Geo, did you drive in Donster's P11? was the ride comparable to your's? Do you know what spring rates he was using?
I used to have the GC/Koni combo back when I was a newbie to the suspension thing, and have no idea what rates I had, but my car got all crazy when hitting a series of small bumps.
I have the tein's now, but I'm really not happy with them anymore, I think the struts are blown!!
b-b00gie is offline   Reply With Quote
Old 11-12-2001, 09:22 AM   #14
Mrcoilover
Originally posted by b-b00gie
Just wondering...
How long you have them?
*Mod List*
2 JL audio W3 12's
Tein type NA (1.7)
Rims coming soon...
Old 11-12-2001, 05:40 PM   #15
P10DET
P10DET's Avatar
I neither drove, nor rode in Don's car. I do however trust his judgement on suspension.
I suspect you needed to do some tuning with your suspension you had before. A series of small bumps can, howver, lead to some jiggliness and harshness no matter the springs/dampers when you are using high rate coilovers.
George Roffe
Houston, Texas USA
00 328i
coil over shock or no coil overs big white bufflo AMC 1 02-06-2025 01:22 PM
Coil Overs to replace stock coils and shocks 99 4WD Rodeo stantony1 Rodeo | Passport | MU 0 09-20-2010 03:28 PM
97 Safari turns over but won't start - ignition coil wires? icemuncher99 M Bodies 3 05-31-2010 06:03 PM
Coil Over XtAz_MaXiMa Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 08-06-2001 09:43 AM
Which Coil-Overs to get agthang Suspension 2 04-12-2001 04:28 PM
