2 quick questions
I just read "How does my selec-trac work" by fredjacksonsan.
#1 I assume the quadra-trac in my 98 works the same as full-time in the selec-trac? New to Jeep...was just wondering. #2 When I turn somewhat sharp, my front end wheel hops like four wheel drive on dry pavement...I am sure my front is out of alignment. Will this cause it to do that? I used to have a Ford Explorer with all wheel drive that did not do this. I am turning no sharper than I have to unless I am on snow/ice.
My current vehicles: 97 Chevy S10 Blazer 4.3 V6 four wheel drive 247,000+ miles 98 Jeep Grand Cherokee Laredo 5.2 V8 Quadra-Trac 188,000+ miles 85 GMC 1/2 Ton Sierra 5.0 V8 four wheel drive 65,000 (actual supposedly) miles |
Re: 2 quick questions
First, select-trac is a 4WD system that mostly 2WD with 4WD to be used on wet or slippery surfaces or 4 LOW for extra torque in loose conditions like sand or mud. Grand Cherokees with the 4.0 came with the NP 242 Select-trac transfer case. Grand Cherokee's with either a 5.2 V8 or the 5.9 came with the NP-249 Qudra-trac transfer case. It has 2 modes, 4WD high or All-time 4WD/AWD and 4 LOW.
If you have a V8, the binding you feel during a sharp turn is because the viscous coupler inside the transfer case is going bad, a common problem on the NP-249 and 247s used on 1999-2004 V8 Grand Cherokees. It costs around $1100 to replace to VC and for that price, you can buy 5 NP-242's for that price. There is a conversion that can done to replace the transfer cases and give you slightly better fuel mileage and less wear on the drivetrain. Worse thing with the binding VC is it will break your front CV axles. I've already replaced my LF axle twice already within a year.
Daily Overhauls Do Get Expensive Dangerous On Days Gears Engage Dead On Day Guarantee Expires Dead Or Dying Gas Eater Department Of Defense Garbage Equipment Dodge Owners Don't Get Excited Don't Overdrive Gutless Engine Drips Oil Drops Grease Everywhere 1995 Dodge Dakota SLT 3.9 V6 1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4 |
Freak nasty,
Thanks for the reply. Been busy & just seen it. I was afraid you were gonna say that. Guess i'll have to explore the options and decide which way I want to go. Thanks again.
I see you live in MO and I'm sure you have snow, so you'll need 4WD but as soon you have warmer weather, I would disconnect the front driveshaft so you don't have to worry about severe crow hop due to the binding VC.
Oh yeah...we definitley have snow. I thought about taking shaft out when it clears up. Thanks for everything.
