Old 01-11-2011, 05:23 PM
racerjim0 racerjim0 is offline
slow drivers window, doesn't seal at speed
motor seems slow going up and the window doesn't always seal when at speed. I have considered flexing the upper door/window outward to where the glass appears to want to go but will wait for some responses
Old 01-11-2011, 05:36 PM
maxwedge maxwedge is online now
A990 racer
Re: slow drivers window, doesn't seal at speed
Try lubing the run channels with some silicone spray, do not bend the door frame unless it was damaged before.
Old 01-11-2011, 09:02 PM
dorfboy dorfboy is offline
Send a message via ICQ to dorfboy Send a message via Yahoo to dorfboy
I would have to say that your window motor/regulator may be going out. They are sold seperately or as a unit. Buying the regulator and motor as a whole unit is much easier to install and it will save you the time and the effort if doing it yourself. Also, I would replace your window guide tracks as well. With your window going off track it puts a strain on your motor and makes it very weak.
Old 01-12-2011, 12:01 AM
danielsatur danielsatur is offline
Cleaning the window on both sides, and using Rainx helps to be less resistance.
Old 01-16-2011, 05:12 PM
Thanks I'll try the rainx. I forgot to say that this is an '08 with only 18k on it
