Old 01-11-2011, 02:38 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
00 Grand Am 2.4L stalls after running awhile
I am working on a 2000 Pontiac Grand Am 2.4L it starts fine, runs fine, plenty of power but after driving 10-20 miles it stalls and won't restart unless you leave it sit for about 10-15 minutes, I was thinking fuel pump was overheating and dying, I sprayed starting fluid in the air tube and it fired right up but died a second later after the starting fluid burned up but I can hear the FUEL PUMP kick on when I turn the key on. Theres no schrader valve to connect fuel pressure guage to on this engine.
Any Suggestions?
Thanks
Joe
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 01-11-2011, 03:32 PM
danielsatur danielsatur is offline
Re: 00 Grand Am 2.4L stalls after running awhile
1) Check pressure at the filter!
2) Also get your catalytic converters tested, I have seen a plugged cat choke an engine out with no DTC's.
