Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-11-2011, 12:47 PM
Cavalier9696's Avatar
Cavalier9696 Cavalier9696 is offline
Send a message via Yahoo to Cavalier9696
Wont stay in 5th gear
I was driving down the road the other day and out of the blue my car popped out of 5th gear. Now it wont stay in 5th gear. I can hold the shifter in 5th and it will drive. It runs fine when I hold the shifter, but from time to time it still wants to pop out even while holding it. Is that a tranny problem or some linkage?
1995 Eclipse RS 5psi
Garret T3/T4 Turbo, Procharger FMU, TurboXS BOV, OBX Evolution 35mm External WG, HKS Intercooler, Apexi DP, Apexi exhaust.
Old 01-11-2011, 02:47 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Wont stay in 5th gear
Could be several things... Could be bad syncros, linkage or possibly tranny damage... I would at least do some tests with the car off and see if you can pinpoint where the problem lies... When this happened to my car it was the result of the intermediate shaft breaking in the tranny... Hopefully it's nothing that bad though. Also it could possibly be a broken motor mount on the tranny side causing the tranny to sag and not be able to go clear into 5th gear... Just some of my thoughts... Good luck though.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 01-12-2011, 08:31 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Agreed with Brian. Could be any of the above. But since it was fine the whole time, popped out and now not staying in it definieltey sounds like something broke.
When my syncros started going out, if driving on the highway it would pop out of fifth about once every 30+ mile trip. Wasn't that bad but still was a problem. When I got the trans rebuilt, never had that problem again.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
The Following User Says Thank You to david-b For This Useful Post:
Cavalier9696 (03-02-2011)
Old 01-14-2011, 03:42 AM
steviek's Avatar
steviek steviek is offline
When I read that first thing I thought was synchros as well
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 01-14-2011, 06:54 AM
ned032002's Avatar
ned032002 ned032002 is offline
On the 1g, theres a nut that backs off inside the tranny and that causes the same conditions your experiencing. Idk if your tranny has the similar setup but you can check into it anyway.
Also check the shift linkage, it could be the lobes around the shifter arms could be worn or stretched. Idk anything about the 420a so if they have a different setup then just ignore me.
Old 01-14-2011, 12:45 PM
IM just going to get it rebuilt and be done with it. I have been hearing prices around $600.00 so I can handle that..hehe love tax time.
Old 01-14-2011, 08:18 PM
ned032002's Avatar
That's cheap for a rebuild but why rebuild it if it doesn't need to be? You may throw money at it and find out that it was a cotter pin on the shift linkage. At least do some trouble shooting before going all in. my .02
Old 01-16-2011, 08:58 AM
david-b's Avatar
Dave is THAT guy
Shifter linkage on the 420a is very similar if not the same to the 4g. You would feel a pull on the shifter itself if the linkage was causing it. Would also be able to hear it pop out with either a slight grind or hear something through the shifter. Would also have problems with 1st and 3rd as well then. There's nothing there to stretch out like that neither. It would either go in gear or not, not pop out.
As far as I know, there's no 'nut' like that on the 420a/neon trans.
That is really cheap for a rebuild. But then again, when I got mine done I got ripped off heavily (FML). But still really cheap. Most places just to pull the trans around here are $250-$300. Make sure it's a good place. Also make sure they have a warranty
75 Monte Carlo
Old 03-02-2011, 06:28 PM
Yup it was the syncros. Thanx guys.
Old 03-02-2011, 06:30 PM
My cousins girlfriends dad did it for me. Why it's so cheap. Why it's good to be in the south, we all know each other...
