Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 01-11-2011, 08:25 AM
vivatflamingo vivatflamingo is offline
Tapping sound
I hear a tapping sound when I accelerate and especially when I'm driving at an incline. What could be the cause?
Also,what kind of oil do I use? and what type of spark plugs should I use? I have a 2004 Lincoln LS V8.
Old 01-11-2011, 08:39 AM
joegr joegr is offline
Re: Tapping sound
Are you using 91+ octane gasoline? If not, then there's your problem. If you are, then you may have some water in your tank. Try a different gas station.
5w20 or 0w20. It must be at least a synthetic blend. Full synthetic is even better.
Use the OEM plugs only.
Old 01-11-2011, 04:02 PM
danielsatur danielsatur is offline
Re: Tapping sound
How many miles is on the Lincoln LS Y2K4?
Try a little octane boost, it could be just bad gas.
Old 01-12-2011, 04:58 AM
Wink Re: Tapping sound
Thx for the info. I will definitely try a different gas station when I fill-up again and try the octane booster. Also, my mileage is about 84k.
