Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-10-2011, 05:55 PM
automps automps is offline
Send a message via AIM to automps Send a message via Yahoo to automps
1996 dodge truck abs code 13
Have a 1996 dodge truck 2 wheel drive with rear only abs . Ground the abs pin under dash looks like code 13 ecm pll failure , Light blinked once then three quick blinks i guess that a code 13 ? abs Module under dash board ? Owner said the brake pedal felt kind of soft . I know the older ford trucks would get the soft brake pedal and anti lock valve on the frame would be leaking pressure . Check all wiring fuses , cleared the codes keeps showing up ... like Trying to get codes out of a rock ! Snap on scanner will nt work on this baby ! Thanks For any help !!!!!!!!
Old 01-10-2011, 10:23 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 1996 dodge truck abs code 13
You may need an ABS compatable scan tool.
My Innova 3160 is supposed to read ABS but I haven't had an ABS light to read yet., here's one.
http://cgi.ebay.com/ebaymotors/Equus...item1e5c7f0867
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
