Old 01-10-2011, 01:30 PM
akeeeno akeeeno is offline
Engine Coolant cap stuck. Any ideas?
I want to add some engine coolant to my car but when I take the cap off, I get this... Any ideas? I can't seem to get it out easily.
Old 01-10-2011, 01:39 PM
danielsatur danielsatur is offline
Re: Engine Coolant cap stuck. Any ideas?
With the cap off, is there a piece of cap stuck in the coolant reservoir tank?
Caution - Coolant can get very hot!
Add 50/50 mix to the cold line on your coolant reservoir tank.
If you don't know what color to use, prestone makes an extended life 50/50 mix for all colors.
Old 01-10-2011, 01:44 PM
Yes, it looks like there's a piece of the cap stuck. Is this something I pry off? Twist off? The underside of the cap looks normal though, I have no clue if and how part of this cap got stuck..?
Old 01-10-2011, 01:54 PM
Doe's it look like a coolant strainer, or a broken cap?
You might need to drill a small hole in the stuck piece in the coolant tank, so you can poke something in the hole and pop it out.
Old 01-12-2011, 07:24 PM
pfofit pfofit is offline
I've had these guys break on other gm's. If it's not opened up enough, the internal o-rings dry up and hardens and coolant crusts up the cap and cause the lip that on the piece that is stuck in the reservoir to let go and all you get is the upper part.
I normally wet the o-rings with a smear of something when I open one up to prevent what you have. Since you have it now, they can be a bugger to release and be careful not to break the reservoir.
It sometimes helps if you can get a bit of light oil between where the leftover cap and reservoir meet. Stick a flat blade between the two in several places and let a bit of oil wick in or run down the blade and then let it sit a bit to work in. This will only lube the upper o-ring. Then work around the perimeter with the blade tip ever so slowly lifting it up. Do not try and pry it up in one go on one side. Two blades on opposite sides is better and if you have an extra arm then three. The trick is straight up, slow and easy, like a gear puller. However a bit of rocking may be necessary if there is a whack of crusty bits at the bottom o-ring.
Good luck
What it is suppose to look like and what your up against.
If it was easy, then anyone could do it.
Old 01-12-2011, 10:48 PM
sparcx sparcx is offline
i almost had a similar problem this morning. cap would get stuck about half way. Luckily i realized that i might break something if i twisted too hard.
I tried again tonite after the car had mostly cooled down but still slightly warm and it finally turned the last bit.
Wonder if it's time to get a new coolant reservoir cap just in case.
Old 01-13-2011, 02:52 PM
Being made of plastic, and heat damage, it's probably worth replacing befor it does break.
Old 01-13-2011, 03:04 PM
You'll find that if you clean it up and lube the o-rings it'll spin on an off in a breeze.
Old 01-13-2011, 08:52 PM
thanks... i might try a little dielectric grease and see if that helps for now
Old 10-12-2017, 10:31 AM
vegastvt vegastvt is offline
hi i have a similar problem on my volvo s40 2007, any tips
Old 12-21-2017, 06:52 AM
Meztrov Meztrov is offline
Lightbulb Re: Engine Coolant cap stuck. Any ideas?
Hey guys, I was super worried because I might of melted my cap onto the tank, but in the end I got it open and here's how...
If it's just too tight.
Then, seriously, just heat the car up, by either idling/revving OR driving it until hot.
hen turn the car off and wait for 20 minutes (not enough for the car to fully cool down).
Go ahead and wear a glove and covering your face (nothing happened to me, but safety first), slowly open the coolant cap (remember lefty loosey). Loosen the cap only about a quarter of a turn, and never fully or even till pressure escapes. Then you should leave it, wait till it cools down fully, then it'll be safe enough to fully open the reservoir cap.
I got mine open after work, when I got home, went upstairs cooked something to eat, came back down, and did as described above. Haven't checked on it yet. Will do in the morning when I go to work again, I'll just add some anti-freeze. It's ratio is consistent of mainly water at the moment. After my car overheated on the way to work a week ago, because I didn't put the cap back on properly the pressure boiled over, spilling antifreeze all over the engine.
If that doesn't work. Buy a wrench that fits around the cap and wrench it open that way, but try to do this slowly so you can assess the situation and not cause further damage. UNLESS of course it tells you specifically to push down before twisting.
