Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 01-09-2011, 09:52 PM
matheu matheu is offline
montana sv6 2006 starting problem
hi all
i have montana sv6 2006 some times when i started it starts but shuts off and i try again it start and stop again and i have to hole the key to start position and keep crancking the car untill starts some people tells me its the tune up and some says its the fuel pump and some says its the battery this is not happening all the time like once or twice a weak .
Old 01-10-2011, 12:35 PM
rkvons's Avatar
rkvons rkvons is offline
Re: montana sv6 2006 starting problem
When it's difficult to start, what are the conditions? Was it the first attempt to start it during the day, was it when it was shut off recently, or was it running just a couple of minutes before attempting to start it?
Old 01-10-2011, 12:45 PM
danielsatur danielsatur is offline
Symptoms of a cold hard start is a bad, or dirty MAF/IACT sensors.
Old 03-15-2011, 10:34 AM
sisson_d sisson_d is offline
My '06 SV6 had similar starting conditions. The first start of the day always worked but still didn't sound strong. After many hours of sitting it would also start the same way. But if I tried to start it within a few hours of it being started already, it would crank, start, and then stall immediately. I would have to hold down the accelerator while cranking to get it to start.
Long story short, I cleaned the MAF and the electronic throttle body with the CRC brand cleaners specific to MAF's and TB's and the van starts strongly every time now. Make sure you use actual MAF cleaner. DO NOT clean it with anything else or touch it with anything.
2008 Montana SV6 - Windshield Wipers problem... Sycko Montana/Montana SV6 7 08-25-2010 06:16 PM
98 Cherokee Starting Problems cdmonday Cherokee 4 01-22-2010 11:13 AM
98 Cherokee Starting Problems cdmonday Cherokee 1 01-21-2010 07:08 AM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
2001 Montana Fuel consumpion/starting problem wbs97gp Montana/Montana SV6 9 04-12-2004 10:03 AM
