Old 01-09-2011, 01:03 PM
sirfairy sirfairy is offline
quick a/c line disconnect tool not so quick.
i have an '88 taurus that i'm attempting to change a faulty heater core on, and i can't seem to disconnect the two a/c lines going through the firewall. i bought a 'quick disconnect' tool from auto zone, but i can't seem to get it wedged under the flare of the pipe to hit the spring, seeing as there is no room against the firewall to get any kind of leverage. any help and/or advice is greatly appreciated. it's cold outside.
Old 01-09-2011, 02:01 PM
hatethewindstar hatethewindstar is offline
Re: quick a/c line disconnect tool not so quick.
when you are using the quik disconnect tool also push in on the line while pressing in on the tool.
Old 01-09-2011, 02:20 PM
brcidd's Avatar
brcidd brcidd is offline
Last one did like that- had corrosion build-up in behind the spring- never did get it apart- after spending a half an hour trying and since I was changing the evaporator anyway- I cut the pipe off on evap side to discover the corrosion- I was replacing the accumulator as well- so it was no big deal--
Those are only quick connects- for use in the factory assembly plant-- no one ever said they were quick disconnects......
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 01-09-2011, 09:40 PM
hatethewindstar, trust me, i've been tugging and pushing every which way. problem is, the removal tool won't slide in right.
brcidd, thank you for that info. if all else fails, that's the route i'll go and i'll cap the lines for now.
Old 01-11-2011, 10:44 AM
okay, so i bought the circular plastic pieces instead of using the crappy metal scissor tool. the plastic one worked immediately. glad i was able to get it loose and spare the a/c evaporator.
Old 04-09-2011, 06:15 PM
Schaff68 Schaff68 is offline
Use PB Blaster or WD 40 on the connections if they are dirty or not coming apart decent. Let the soak about 5-10 minutes.
