Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 01-09-2011, 12:00 PM
jstride jstride is offline
stripped
fill plug on rear diff. is stripped. whats the best (easiest) to get out
Old 01-10-2011, 06:46 PM
777stickman 777stickman is offline
Re: stripped
If it's an external square fitting, big vice grips.
If it's an internal square or torx fitting, big "easy out".
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 01-10-2011, 07:52 PM
j cAT j cAT is offline
Re: stripped
what did you use to remove this plug ? this is a square hole not allen wrench ! I don't get how this occured..
Old 01-13-2011, 02:21 PM
Re: stripped
i attempted to remove the plug and it has been rounded off on the internal square hole. looks like its going to be a pain
Old 01-13-2011, 02:33 PM
Re: stripped
the use of a rachet extension with a rachet should do it ..
if the hole is rounded get an easy out kit with various sizes and see if it will remove it ..use some heat with a small torch to get the plug hot ..
lastly use a 1/4 in drill hole on the centre of plug then use the easy out..
you must have a new plug first..
torque on the plug should be 15-20 ft lbs !
Old 01-14-2011, 09:55 PM
Cusser's Avatar
Cusser Cusser is offline
Re: stripped
Big vise-grips. Then get a new plug.
Or just take out all the cover perimeter bolts, take off the entire cover, let a machine shop fix it, or, if cheaper, just buy a replacement cover and plug.
Old 01-15-2011, 08:34 AM
Re: stripped
cover has drain fill plugs ???? these are on the diff housing !
Old 01-20-2011, 11:01 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: stripped
The fill plug is a female, 3/8" square plug. A 3/8" ratchet wrench end fits into it. It is on the side of the diff housing, not the removable back. If it got rounded off, it must be seriously seized which is odd because of the diff lube that is usually in the threads.
You'll need a big easy out, some PB Blaster and/or some freeze rust breaker spray. Alternatively, you could try to cut a slot in the head, but you'll need a LARGE screwdriver or pry bar.
Good luck & let us know how it turns out!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 01-20-2011, 02:07 PM
Re: stripped
could be someone used thread locker permenent ! if so the torch should do it.
