Go Back   Automotive Forums Car Chat > Buick > Regal
Old 01-09-2011, 10:03 AM
caddiali caddiali is offline
unusual idle while only in park
97 Regal LS 190kms
Hi when the car is on and in "park", the idle is inconsistent. Rpm tach needle moves enough to notice. Drives fine in "drive" I've lifted the hood and it sounds like the "chugging" is coming from around the alternator area. There is no service engine light on. Im wondering if this is a sensor?
side notes: -had fuel filter replaced last week..
-used engine replaced Oct/2010.
Any ideas/feedback appreciated
Thanks!
Old 01-11-2011, 08:25 PM
Re: unusual idle while only in park
Update on rough idle: had a friend mechanic take off engine cover, noticed a vacuum line was loose. So he secured it back in place and now the car is at normal idle. Will continue to start it up and let it run to monitor any unusual sounds.
Im wondering what vacuum line this is? Any ideas?
thanks!
Old 01-11-2011, 08:59 PM
danielsatur danielsatur is offline
A vacuum line is used for some type of switch, any leak would of caused your idle problem.
Old 01-14-2011, 09:25 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
do you know what area the vacuum line was in? There are many for underhood components like the canister purge valve (mounted to front of UIM), fuel pressure regulator, HVAC vacuum supply, etc... just to name a few.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 01-14-2011, 05:52 PM
I will ask the handy man who re-attached the line and update the forum. I remember when he pulled it off completely there was a "hissing" like sound..
Thanks for your insight, you sound very knowledgeable about these Buick's!
