Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 01-09-2011, 09:40 AM
wjbean wjbean is offline
DPRE to EGR Hoses
I went by my Lincoln dealer and parts house in search of the two very narrow hoses that run from the DPRE to the EGR valve. In checking for a vacuum leak I snapped one of them and want to replace both (they are green and red in color). The dealer tells me they are now obsolete. Not good.
Anyone know where I can get these? I need them to pass smog.
Old 01-09-2011, 02:03 PM
danielsatur danielsatur is offline
Re: DPRE to EGR Hoses
There's a graveyard of used parts for the 4.6 TC, I would have no problem replacing both the DPFE sesnor + vaccum hose connections.
Old 01-09-2011, 02:45 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Junkyard.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 01-09-2011, 06:20 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
If the ends of each hose are OK you can go to any autoparts store and grab some 1/8" rubber hose to replace the nylon part, just leave a small piece of nylon and insert it into the rubber hose at each side, you can use some silicon sealant to make sure you have no leaks. Finally you can try searching at the "vacuum parts" department of the autoparts store, autozne has different nylon hoses and adapters that would definitely do the trick.
Best regards,
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
PCV hose question and sourcing - '95 Blazer recurve Problem Diagnosis 6 03-08-2010 12:43 AM
92 Cutlass Supreme Power Steering Hose Mikey_G Cutlass Series 4 11-23-2009 01:47 PM
How do I remove heater hose? uspres2020 ZX2 1 10-03-2009 08:35 PM
Lower radiator hose cool/Water pump squeal ktl4974 Problem Diagnosis 7 05-04-2009 08:44 PM
1981 egr hose sammy81 Corvette 7 03-09-2005 12:43 PM
Tags
dpre , egr , hose , hoses
