Old 05-24-2003, 09:54 AM
Rob80 Rob80 is offline
Send a message via AIM to Rob80
Cam Gears, what are best?
I was looking for the best bang for my buck cam gears. I was looking at skunk 2 cam gears for my b18b which is going to be turboed. However I saw the str pro series for much cheaper. Like 150 for a pair. They have 5 screws, one less than the skunk 2's but are like 70 bucks cheaper. Does anyone know if they are any good or knows of a real good cam gear. Also what about the JG's, venoms, and golden eagle's? I figured the STR and skunk 2's would be better cause they have more screws but I'm not sure, If anyone can help please do or if you have a good or bad experience with a cam gear please share.
thanks
Old 05-24-2003, 07:40 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
Buddy of mine has the STR's and they slipped and cost him a couple runs at the track.I've heard a couple other stories of them slipping too.
Old 05-25-2003, 11:39 AM
which str's though
which str's are you talking about though, there are cheap three screw str's and there are the pro which have 5 screws. I figured a cam gear with five screws wouldn't slip often. When I looked up the STR's initially I saw those three scew ones and I laughed. Can you check with your friend and see which ones he had. Thanks a lot.
Old 05-25-2003, 03:49 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
get cam gears that have 6 things to tightent he cam gear in place so it doenst slip. like the aem ones suck, get like skunk2. aem only has like 3 or 4 tighting bolts, while the skunk has 6, get the 6 so it doesnt slip
Team Lonely Drivers
Old 05-25-2003, 07:12 PM
5 or 6
Well that's why I was asking, skunk 2 has 6 and the STR has 5 but the STR are much cheaper so I was seeing if anyone had experiences with them.
Old 05-27-2003, 10:59 AM
88_SC_CRX_Si 88_SC_CRX_Si is offline
Which ever one's you get, keep an eye on them for wear around the notches/teeth where the timing belt rides. Some of them well wear quicker and the belt to start jumping the notchs/teeth. Causing the piston and valves to crash into each other in some cases....
"Noth'in like Induction..."
88' CRX Si - JRSC @ 6psi Z6 Mini-Me, JDM SiR Conversion
NOS #5122, JR Liquid InterCooling System
ZYDNE SECU, 450's
B&M FP Set, B&M Command Flo
AutoMeter - Phantom FP, A/F, N2O, Boost gauges & pods,
ARP HSKit, AEM Pads, 87' HF Drums, DYI CAI
Old 06-02-2003, 07:20 PM
For those that are interested in this thread I've decided to go with crower cams, because they use ARP studs. No SLIPAGE
Old 06-02-2003, 07:47 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
wasnt this thread about cam gears?
i didnt even know crower made gears.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
