Old 01-07-2011, 11:37 PM
rtx042's Avatar
rtx042 rtx042 is offline
2001 2500 Silverado runaway cruise control
Just picked up a 2001 Silverado 2500 with 200k on it. 6.0 engine runs well but while we were on the highway the other day with cruise set at 118 km/hr. the vehicle slowly started to accelerate. At about 135 km the brake was applied and we were able to scrub off 20 km/hr down to 115 before the brakes started to fade and heat. Tried to hit the brake pedal numerous times as well as shutting the cruise control off and on 6 or 7 times. After about 5 minutes of this it finally kicked off and we pulled over. I pulled the cruise control 10 amp fuse and we lost the fuel gauge as well at having the red battery problem indicator light up.
I spoke with a Gm mechanic and he said that his initial hunch would be a failed cruise control module. I found one at a wreckers for $100......GM wants $725 for a new one!
Just wondered if this had ever happened to anyone else with this truck and what might have caused it?
email [email protected] if you have a solution...thanks!
.Rob
Old 01-08-2011, 09:23 AM
j cAT j cAT is offline
Re: 2001 2500 Silverado runaway cruise control
.Rob
before buying any parts make sure the cruise control cable is not binding..
since you turned the cruise off, hit the brake pedal and the vehicle still did not reduce speed it cannot be the module.
the cable can stick.. this is an old high mileage vehicle ..
post back what you found.
another issue this has is the throttle body needs cleaning with throttlebody cleaner and a tooth brush..
do not use carb cleaner on this engine anywhere !
when cleaning use small amounts DO NOT FLOOD ENGINE WITH CLEANER !
Old 01-08-2011, 11:17 PM
4x4junkie 4x4junkie is offline
continuing to accelerate while braking is most likely as Jcat said the cable for cruise control binding or sticking.
4x4Junkie
2012 silverado 1500 ext. cab LT
Z71 4x4 with allstar package
5.3L V8 Flexfuel with 6 speed AT
Onstar / Sirius XM
Factory Tow Package
Electric Brake Controller
Silver Ice Metallic
265/65/18
Wifes Vehicle
2014 Kia Sorento EX AWD
3.3L V6
Toys
2007 Yamaha VStar Silverado
1086cc 45 degree vtwin
Grey and Silver
GPS positioning locator installed
Old 01-08-2011, 11:34 PM
777stickman 777stickman is offline
Just to add to this: Your biggest safety valve is the ignition switch if this ever happens again. In other words, turn it off and get off the road.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
2001 Grand Cherokee No Cruise Control RADJAD Grand Cherokee | Grand Cherokee SRT8 0 12-21-2010 12:12 PM
Cruise control freak out cobraprince 3000GT/Stealth 13 03-23-2009 10:41 AM
1998 Zx2 Cruise Control Problems ddppci ZX2 1 02-17-2009 10:59 AM
2001 Malibu and the Cruise Control shutting off. ddev Malibu 1 01-21-2008 03:41 PM
