Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-07-2011, 11:13 PM
ss101504 ss101504 is offline
Car just randomly shut off. Please help.
This morning on my way to work, my car just shut off. No warning, no nothing. What happened was i was merging onto the highway, after exiting the interstate, and when i went to speed up, the engine just died. just like if someone had shut off the ignition. not sure whats causing it, but i am getting fuel at the injectors, and fire at the plugs. Also the battery is fully charged, the fuel pump, fuel filter, and injectors are a few months old, and had a tune up about 6 months ago. Any help y'all can provide would be greatly appreciated.
Old 01-07-2011, 11:23 PM
danielsatur danielsatur is offline
Re: Car just randomly shut off. Please help.
How old is the battery?
New cars demand alot of battery power.
Old 01-07-2011, 11:27 PM
Battery is maybe 3 month old, and it was checked. Everything seems alright. and its not a new car. unless this is 1992. Which if it is, I might be able to wear parachute pants, and be cool. LOL.
Old 01-07-2011, 11:32 PM
Make sure the battery terminals are clean + tight.
You shouldn't beable to move by hand, and I don't want to see any corrosion on battery cables.
If battery terminals were dirty + loose, the alternator wouldn't be able to charge the battery.
Can you honk the horn with the bright lights on?
Old 01-07-2011, 11:37 PM
The battery cables are clean and corrosion free. The battery has been maintaining a charge. I guess to clarify, when the engine died, I still had full electric power. Headlights were still on and strong, and the stereo was still playin.
Old 01-07-2011, 11:43 PM
If your Lights + horn work, this rules out the battery.
Check for fuel on the fuel injection rail!
Are you getting any fuel?
If not, check both the fuel pump fuse and relay.
Old 01-07-2011, 11:47 PM
Car has TBI. And I am getting fuel at the throttle body from both injectors.
Old 01-07-2011, 11:52 PM
Sounds like an ignition problem, need to check for spark at plugs.
Old 01-07-2011, 11:53 PM
I do have spark at the plugs.
Old 01-08-2011, 12:02 AM
Got a spark, but is the ignition timing good?
Old 01-08-2011, 12:03 AM
Timings good.
Old 01-08-2011, 12:42 AM
Have the ignition module bench tested.
Old 01-08-2011, 01:06 AM
The coil has been tested, and is working. (At least getting spark to the spark plugs.)
Old 01-08-2011, 10:26 AM
j cAT j cAT is offline
with a good blue spark, engine cranks, and fuel in the intake and the engine does not start or run this may be a timing chain ..
1992 is a year I am not to familiar with ..
what about any antithieft devices installed...if so remove disable them ..
if the spark is yellow or weak the ignition module or even the distributor maybe defective..
Old 01-08-2011, 11:51 AM
Scrapper Scrapper is offline
AF Premium User
dose your car sound like it's turning over real fast if so i would say timing chain if no compression.could take cap off and turn it over and see if rotor button turns if not it is the timing chain.
