Old 01-06-2011, 09:25 PM
TAvsGN TAvsGN is offline
01 GP GT stuck in park
My wife's 01 GP GT keeps getting stuck in park and will not go into gear. The key comes out fine, and the car starts fine. There are brake lights and the shifter button can be depressed. When I depress the button, there is a click from under the steering column. After searching for awhile here, it sounds like either a fuse or a stuck/bad BTSI switch (which is under/part of the shifter if I am correct). Would this be correct? Any other thoughts? And is the BTSI a dealer only part? What is the part number? Thanks!!
01 Grand Prix GT
01 Dodge Ram 1500
98 Trans Am WS7
87 Grand National
78 Firebird Formula
77 Grand Prix SJ
Old 01-07-2011, 08:57 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 01 GP GT stuck in park
You might try taking the console apart and cleaning the BTSI, as it's possible some sort of beverage was spilled down there causing our issue. You are correct in that the BTSI is not sold seperately and is part of the shifter which is dealer only. The shifter part numbers are 10323933 (w/leather shift knob) and 10323934 (exc leather shift knob). These parts were used from 00-03 in Grand Prix's, in case you wanted to search the salvage yards
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 01-11-2011, 04:19 PM
Just an update. Took the shifter assembly apart and found that 3 out of 5 wires going into the BTSI were either loose or broke at the plug. Got a $1.30 plug from the local Pull a Part and it is working like it should again.
01 Grand Prix GT
01 Dodge Ram 1500
98 Trans Am WS7
87 Grand National
78 Firebird Formula
77 Grand Prix SJ
Old 01-11-2011, 04:25 PM
richtazz's Avatar
Nice job, and thanks for the follow up. It may help another member with a similar problem in the future doing a forum search.
stuck parking brake dreiber10 Caravan | Voyager 1 08-07-2007 10:12 PM
stuck parking brake 93 amigo dalfbri1 Amigo 1 04-05-2005 08:13 PM
Stuck Parking Brake Dropped2KNeon Neon | Plymouth Neon 2 10-24-2004 07:14 PM
Stuck Parking Brake ganik17 Celica 5 08-06-2004 06:59 PM
98 Jetta stuck parking brake bradjetta '97 - '03 4 01-27-2004 08:12 AM
