Go Back   Automotive Forums Car Chat > Ford > Contour
Old 01-06-2011, 05:29 PM
CarDood260 CarDood260 is offline
Unhappy Stalling, Grinding, and Rough Idle..
The car is a 1996 Ford Contour SE V6 2.5L with roughly 82,000 Miles.
I had some previous trouble with a hard idle when I started it up where it would idle around 400RPMS and then often cut out on me. I had it worked on at a local shop and they replaced all spark plugs, put in an injection cleaner, and then all vaccum pumps. That worked for about a week.
Then, I blew another spark plug and a gasket, this time however when it was fixed it was a more controlled idle but still sometimes would just shut off after being fixed.
As I was drving the other day I noticed a hard grinding sound after shifting into gears. Each gear would grind very hard and I had little or no power response when I floored the accellerator pedal. Also, the car still cuts out with any warning when coming up on a stop sign or stop light when I shove the clutch in and brake. I'll list some of the problems I'm having below, Please help me diagnose this
-Takes longer to crank and turn over, Idles around 1000RPM and sometimes just shuts off.
-Rather Rough Idle.
-Cuts out alot when stopping at a light or sign.
-Easy shift into gear but extremely hard "clicking" grind when I accellerate.
-Power lacking in gears, and struggles really bad going up hills. First gear struggles on getting me up hills I usually can get up in 4th gear.
-The grinding sound seems to be coming from somewhere in the front on the drivers side
Old 01-29-2011, 08:34 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: Stalling, Grinding, and Rough Idle..
MTX or ATX?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Repair Manual and Rough Idle jpar1983 Intrigue 4 09-21-2011 03:59 PM
99 Caravan Sport Rough Idle and Stalling blase Caravan | Voyager 8 10-10-2010 07:48 PM
2000 Ford Mustang Grinding Noise While Idling Starbucksinhand Mustang Problem Diagnosis 1 02-03-2010 01:59 PM
Help with 97 Villager rough idle dscott1838 Villager 12 05-09-2009 09:34 AM
Rough Idle Mayathebee Cougar 1 03-22-2009 08:23 PM
