Old 01-06-2011, 08:45 AM
mustangemd19's Avatar
mustangemd19 mustangemd19 is offline
Revell Ferrari Enzo fitment issue (Help)
Just bought this the other week and noticed the rear hatch does not close down all the way. I've tried shaving etc. but no luck. It looks like it is warped almost, I've tred bending it back but I'm afraid to go to far with it and break it.
I have seen another completed Enzo with the same problem so any tips on fixing it would be great. If I can't fix it I will just glue it down
Any help would be greatly appreciated.
Old 01-06-2011, 09:04 AM
ZoomZoomMX-5's Avatar
Re: Revell Ferrari Enzo fitment issue (Help)
Looks warped to me. You can see if Revell can send a replacement (do it via email though their website-people report no problems, no expense, vs. their phone number), or you can attempt to massage the warp out by bending/twisting it carefully in the opposite direction. Seems like their plastic is soft enough these days that you should be able to get it fixed that way. Revell Enzos have better body panel fit than Tamiya....and their respective engine covers are identically sized; they can be swapped between the two models.
My Fotki Album
Old 01-06-2011, 09:10 AM
Thanks, I'll try contacting Revell to get a replacement. Didn't think about doing that.
Old 01-06-2011, 09:35 AM
drunken monkey's Avatar
Razor Sharp Twit
hot (50+ degrees celcius) water to heat the plastic before attempting to bend it back into shape might help.
a cold bath after the bending seems to help "set" it after bending when hot as well.
could just be psychosomatic though...
AF's Guidelines
Read them.
Old 01-06-2011, 09:44 AM
Just ordered a replacement part from Revell. If the issue happens again though I will for sure try that.
Thanks for the tip.
Old 01-06-2011, 09:49 AM
Razor Sharp Twit
just so you know, i said 50 degrees c because that is the temp that my hot water boiler is set at and so it is what comes out of my tap.
there is absolutely no scientific reason for that number other than that...
also, sometimes, the place that you need to apply pressure isn't where you think it is.
a warp as you show on your part could start from anywhere between those two opposite corners and the warp itself could be gradual over that entire corner.
what that means is that if your were to try and bend it back innto shape under heat, you would need to do it bit by bit over that area instead of just twisting it over a single line on the plane.
AF's Guidelines
Read them.
Old 01-06-2011, 10:26 PM
935k3's Avatar
935k3 935k3 is offline
After you get a non warped body here is an idea that will lock down the deck when shut. I glued a small .030 square strip of plastic inside of each fender(as shown in pic) when closing the deck you spread slightly then it catches under the inner fender part of chassis. I did have to bend mine some to.
Old 01-07-2011, 01:37 AM
I'll try that.
Thanks
Revell ferrari Enzo [1/24] AdamDK WIP - Street 4 12-28-2009 07:33 AM
The warm up Revell Ferrari Enzo johanthemodeler WIP - Street 26 03-24-2007 11:47 AM
Revell Ferrari Enzo Problems mhayward Car Modeling 8 12-08-2006 04:37 PM
Revell Ferrari Enzo Vyacheslav WIP - Street 10 11-11-2006 10:12 AM
WIP: Revell Ferrari Enzo "Giallo Modena" SkylineFan WIP - Street 40 01-27-2006 09:16 PM
