Go Back   Automotive Forums Car Chat > Toyota > ES300/ES330/Windom
Old 01-05-2011, 04:07 PM
tallen2222 tallen2222 is offline
need lexus help
hey everyone ive got a 1992 lexus es300 150k here is the problem sum days when i start it up or after i shut it off it just cranks and cranks you have to press gas peddle and rev it up when it does finally start and it runs perfect after that sum days however you have to crank it enough that battery gotta get jumpd if you press the gas pedal it will stumble for half a second then just keep cranking.idle air control vavle has been changed twice and visaully all i could see under hood is the steel line feeding fuel filter is twisted a little tho its been like that over a year.all of this started after trans shop changed fluid. ide appreciate any help
Old 01-24-2011, 11:42 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: need lexus help
Check the EGR (exhaust gas recirculation) valve for operation and if it is clogged. Also, check the ECT (engine coolant temperature) sensor. Either or both can cause a no-start or hard start condition.
Good luck and welcome to AF!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 05-10-2011, 12:50 PM
exoticdealer exoticdealer is offline
Re: need lexus help
I would check the EGR there mate.
cheers.
