Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 01-03-2011, 06:51 PM
46u 46u is offline
Upper intake (Plenum) question 97 88 LS
I got the old plastic upper intake (plenum) off my 1997 Olds eight eight. When I took it off the gasket and everything came off. No real problem but leaves me with a question. As most know the gasket is a thick plastic gasket that has a bead on each side. Going from front to back there are two plastic supports that hold a pipe. I am guessing one end is open to the cavity and the other end goes into the hole going to the PCV is this correct? I looked in my manual and did a search online but could not find anything that confirms this. Too muck to have to take the new one off later so please advise me.
Thanks!
Old 01-04-2011, 04:04 PM
maxwedge maxwedge is offline
A990 racer
Re: Upper intake (Plenum) question 97 88 LS
Correct, while you are in there, remove the 2 inside corner lower int. bolts ans seal them with rtv, oil can migrate up these bolts.
Upper Intake Manifold on Series I and other questions jaimysessanna LeSabre 6 01-25-2010 02:15 PM
Readdy to do my upper intake, few questions happydog500 LeSabre 1 04-14-2007 10:22 PM
93 PA upper intake manifold question sleo33 Park Avenue 3 02-27-2007 03:38 PM
Upper intake manifold question budbowl7 Tahoe 0 01-15-2006 05:58 PM
Removing the upper intake resiewdub F Series 2 12-09-2003 09:16 AM
