Go Back   Automotive Forums Car Chat > Chevrolet > Lumina APV
Old 01-02-2011, 07:21 PM
OppieT30 OppieT30 is offline
Send a message via ICQ to OppieT30 Send a message via AIM to OppieT30 Send a message via Yahoo to OppieT30 Send a message via Skype™ to OppieT30
Chime dinging with headlights on and car running
91 Chevy lumina APV van
Chime chimes with engine on and headlights on and doors closed.
Old 01-04-2011, 05:47 AM
LMP's Avatar
LMP LMP is offline
Re: Chime dinging with headlights on and car running
Which individual condition will let you stop the chime?
I'd suspect the door switch. Do you have keyless entry ?
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 01-05-2011, 12:12 AM
Actually went and started pulling fuses and it was one of the fuses that was bad.
Old 01-06-2012, 03:15 AM
RWBUFFALO RWBUFFALO is offline
Had this happen to me last month.First the chime,then started noticing other electrical problems(wipers slowed,service engine light,etc).I measured the voltage and it read approx. 7 volts.I assumed it was the alternator,replaced it,same problem.After rooting around in the engine compartment for awhile,it began blowing a fuse when i tried to start the vehicle. I realized there was a short.Started checking everything on that circuit(ign.,alt.,a/c relay).It ended up being a small break in one of the wires going to the a/c relay. Initially not enough to blow the fuse,but enough to put a drain on the voltage. I believe the chime came on because it sensed low voltage, as if the vehicle was shut off but your headlights were still on.Hope this helps,took me all day(relay wiring was last thing I checked).
