Old 01-02-2011, 07:20 PM
hatethewindstar hatethewindstar is offline
aluminum valve cover for the rear of a 2000 3.8 ????
I bought the upgrade cover for the front but what did these aluminum covers come from and if from another car would the breather hole be in it for that tube that goes by the MAF sensor?
Old 01-02-2011, 07:40 PM
mark_gober mark_gober is offline
Re: aluminum valve cover for the rear of a 2000 3.8 ????
Hate,
I'm not sure exactly what you're talking about, but if it's the "new style" valve cover gasket that was part of the recall, it should be a direct fit. The hole is there in mine and mine is a new style. I believe that the only change was the addition of a baffle under the PCV valve. (I might be wrong on this).
If this is what you're referring to, cool. If not, expand a little and I'll see if I can help.
Mark
Old 01-02-2011, 07:45 PM
Originally Posted by mark_gober View Post
Hate,
Mark
Actually I mean a matching one for the other side
Old 01-02-2011, 11:43 PM
I don't believe that an upgraded rear valve cover was ever designed. The rear cover doesn't have any openings that I remember.
Mark
Old 01-03-2011, 09:33 AM
wiswind wiswind is offline
The upgrade was a improved baffel in the front valve cover for the PCV valve location to reduce the amount of oil droplets that are pulled into the motor through the PCV system.
It IS normal for some oil to be present through the PCV system, but the old style valve cover used in 1999 and 2000 permitted more oil to get through.
The rear valve cover was not changed and only has the hole for the breather, air passes from the flexible hose between the air filter and the throttle body through a plastic tube that connects to the rear valve cover.
Take note that the PCV valve is in the front valve cover from 1999 and newer.
The PCV valve was in the rear valve cover , with the breather in the front valve cover in 1998 and older.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 01-03-2011, 12:45 PM
So do 2001-up have a rear aluminum valve cover? I know it isn't a upgrade over mine but just want an aluminum cover for the rear of the engine now so they both match.
Old 01-04-2011, 11:34 AM
MARZBX157's Avatar
MARZBX157 MARZBX157 is offline
Why not just buy some black engine paint and spray the new cover to match the other one? That's what I did, although you can't really see the rear cover when looking from the front.
2000 Windstar 3.8 V6
Old 01-06-2011, 11:40 AM
Because I have the other one off anyways to change a broken valve spring. So figured now is the time to put an aluminum cover on that side.
Old 01-06-2011, 12:14 PM
Scrapper Scrapper is offline
AF Premium User
cant believe i'm saying this but go to pep boys or call them. another thing to do it might cost you more but it's worth it try jeggs and or summit.
