Old 01-02-2011, 12:07 PM
glenmalkowicz glenmalkowicz is offline
put diesel in my gasoline oldmoble cutlles!!!
i recanly accsidenly put diesel in my oldsmobile cutless, it was almsot empty of gas and i poured like 15 bucks disal in it, i drove for a couple mins and then i started to bog out and that so i stoped, and relized it was diesel, i drained all he diesel and put gas in it, i turned it over for a min and it started up, but it only runs for 5 seconds then turns off, it starts right up but it only runs for 5 seconds, NOTE: THE CAN A DIESEL ALSO WAS VERY DIRTY, so maybe somene got cloged up with dirt, do u think the fuel filter might jut be clogged??? thanks
Old 01-02-2011, 12:18 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: put diesel in my gasoline oldmoble cutlles!!!
When you say you "drained all the diesel" did you just siphon it out or did you drop the tank, drain it and wash it out?
Unless you dropped the tank, chances are there is still enough dirty diesel in there to prevent the gasoline from burning properly.
So....... drop the tank, drain all the gas/diesel in there, and wash it out with detergent. I like to take an empty tank to the local car wash and use a high-pressure wand on the inside, with soapy water. This will help get rid of any dirt and diesel residue/wax.
Then, rinse the tank thoroughly and allow the tank to dry. Before reintalling, remove the inline fuel filter (if its fuel injection). Disconnect the fuel line up by the engine and blow-out the line with compressed air.
If the car has a carburetor, remove it and rebuild it, and ensure its clean. The residue and wax from diesel will plug-up all the carbs jets.
Then, when the tank is dry, reinstall it. Install a new fuel filter, hook up the fuel line under the hood, add fresh gas and start it up.
Old 01-02-2011, 12:40 PM
Scrapper Scrapper is offline
AF Premium User
my sister done that to my dads car way back and then next day my wife did it ay a clark station and both were at clark but 2 diffirent place. and when i done wifes car i changed everything cap,rotor button,coil before i found out. finaley when i got it started i bet i put 150 mls. to get it out. i got allot of mls per gallon out of that deal. when you fill it up use a whole can of sea foam after you do what magic told you what to do.
Old 01-02-2011, 12:59 PM
thats alot of work though, i might just change the fuel filter first
Old 01-02-2011, 01:05 PM
AF Premium User
yah after i ran it out of the 1970 nova i never had to clean nothing ran fine. if you just change filter i would turn key on and let it get out of the line.
Old 01-02-2011, 01:16 PM
yeah mines fuel injected
Old 01-02-2011, 01:31 PM
AF Premium User
is it multiport or throttle body injection?
Old 01-02-2011, 01:35 PM
Multi-point
Old 01-02-2011, 01:46 PM
AF Premium User
Multi-point
then for sure i'd run a can of sea foam threw it to get it out of the injectors.
Old 01-02-2011, 01:56 PM
so do i just pour that in the tank
Old 01-02-2011, 02:17 PM
danielsatur danielsatur is offline
1) Disconnect the fuel filter, and connect a 4-6' hose in its place.
2) Place the other end of hose in a 5-gal gas can.
3) Disconnect the fuse going to the ignition module, so it doesn't start.
4) Turn the key on, and let the electric fuel pump do it's job.
If this car has a mechanical fuel pump, you need to turn the starter over to pump fuel out.
5) New fuel filter
6) Octane boost
7) Fill her up!
$15 of diesel < 5gal , you might consider to siphon some bad fuel 1st, befor letting the fuel pump do it's job. There will be less of a load on the battery.
How much fuel was in this car, befor the $15 of diesel?
Old 01-02-2011, 02:45 PM
i already did that and there was no gas in the car when i put the disael in,
Old 01-02-2011, 06:44 PM
MagicRat's Avatar
If the diesle was clean, sure draining and diluting it will work. But if the diesel is as dirty as Glen indicates, dropping and cleaning the tank is best. It's really no big deal to do at all.
Old 01-04-2011, 01:41 PM
AF Premium User
yes just poor it in the tank.
Old 01-04-2011, 09:16 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
I wouldn't suggest using water to blast it out. The tank has baffles that are designed to retain gas near the pump and sucking in water can be bad for the pump and sender...rust can form quickly. I'd use a solvent instead such as carb cleaner or a bottle of your favorite fuel system cleaner (the exception being a methanol- or ethanol-based cleaners...these can cause rubber parts to swell up in high concentrations and long soak times). It can dissolve any gunk that has formed and help pass it through the pump easier. Plus, any cleaner still left in the system can be burned by the engine or dissolve into the gasoline.
Also, some fuel injection systems will automatically shut the pump off if it doesn't detect the correct fuel pressure or after a certain length of run time with the engine off. I had to drain my truck's tank last summer and had to cycle the key on/off a number of times to keep the pump running.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
