Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 12-31-2010, 06:53 PM
20GMC00 20GMC00 is offline
01, 02, 03 Dakota Brakes
I have three Dakotas. An 01, 02, and an 03. One V6 and two V8's. When they are first started in the morning, the rear brakes will lock up on them for the first few stops. Then, they dont do it after they have warmed up. Anyone have any ideas? Thanks.
Old 01-12-2011, 11:55 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 01, 02, 03 Dakota Brakes
did you ever figure out what was wrong? You could have a bad proportioning valve.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 01-21-2011, 08:22 AM
t_arnold's Avatar
t_arnold t_arnold is offline
My first thought would be old brake fluid. Especially if you live in colder weather right now. The moisture in old brake fluid will freeze, causing the problem in the rear drums. I would completely flush the old brake fluid, bleed the system, and then see how it does. You will probably notice better feel from the brakes. Almost like a new truck.
Timothy F Arnold
Old 03-28-2011, 04:57 PM
Burt the Boater Burt the Boater is offline
With any luck, you have already solved this problem. If not, a rear brake drum inspection is in order. The self adjusters do not work. I adjust the rear brakes once a year (I have a low mileage 2001). Many folks have driven their Dakotas to the point that the front rotors warped because the the rear brakes were not providing the intended braking forces.
Both of my front calipers locked up and had to be replaced.
Bleeding brakes on an annual basis is a good preventative maintenance measure.
Cheers,
Burt
02 dakota we brake problem span0201 Dakota 2 04-07-2009 11:22 PM
02 Dakota Quad Cab 4x4 - brake noise! carcrazysincebirth Dakota 2 10-27-2006 02:53 PM
Heavily considering an 01/02 Dakota wurldwyde Dakota 0 11-10-2004 10:41 AM
