Old 12-30-2010, 06:44 PM
pspencer15 pspencer15 is offline
Bravada Starting issue
Ok so today i went out and the truck started fine a few times, and then one "click" then nothing. The lights are bright, everything comes on fine, the voltage reads 12 volts, but when I turn the key, nothing. Not even a click. No battery drain, just no nothing. The alt is new. The battery is just a year old, I tried to jump it. nothing. I checked all the fuses, I checked the wiring and everything looks fine. It sounds to me like the starter. Any other thoughts?
Old 12-30-2010, 07:34 PM
old_master's Avatar
Advisor/Moderator
Re: Bravada Starting issue
What year?
You have to know how it works,
to figure out why it doesn't.
Old 12-30-2010, 08:33 PM
Its a 1999. 4.3 vortec with that wonderful smarttrak all wheel drive.
Old 12-30-2010, 09:04 PM
old_master's Avatar
Advisor/Moderator
The starter relay is located in the underhood fuse panel, check the underside of the fuse panel cover for the exact location in the fuse panel. Have an assistant hold a finger on it while you attempt to start the engine. Does it "click" when the ignition is turned to the START position?
If not, move the shifter to NEUTRAL and try again. If it still doesn't click, let me know.
If it does click, continue checking, this time at the starter:
Check the black cable terminal AND the stud that the cable connects to. They both should show battery voltage at all times.
Also at the starter: Check the purple wire, it should show battery voltage when the ignition is in the START position only.
Post your results.
Old 12-30-2010, 09:26 PM
OK. No clicking while in neutral.
Old 12-30-2010, 09:34 PM
old_master's Avatar
Advisor/Moderator
In the underhood fuse panel, check the 40 amp fuse labeled "IGN A" with a volt meter or a test light, on both terminals on the visible end of the fuse, (do not remove the fuse to test it). The fuse is a larger size fuse, probably in a row with several others the same physical size.
Old 12-31-2010, 08:16 AM
old_master's Avatar
Advisor/Moderator
Also in the underhood fuse panel:
1) Check both sides of 20 amp "IGN C" fuse, it should show battery voltage at all times.
2) Check both sides of 10 amp "CRANK" fuse, it should show battery voltage when the ignition switch is in the START position only.
Post your results on these also.
Old 12-31-2010, 01:07 PM
It was the starter. Man it was a PAIN getting it out. There is just no room under there!
Old 12-31-2010, 02:02 PM
old_master's Avatar
Advisor/Moderator
Yup, tight quarters! Glad you got her fixed and thanks for posting back. It's odd that the starter relay didn't click... it sends current to the solenoid on the starter and without it the starter will not engage. The relay is pretty quiet so, who knows.
