Old 12-30-2010, 04:42 PM
mudbone88 mudbone88 is offline
Angry cherokee will not take 4 wheel drive
i have a 1990 cherokee and yesterday the part time 4 wheel drive light came on just going down the road , so today i tried to put it in 4 wheel drive and it won't go just the back tires will spin. whats up with that. thanks for any help.
Old 12-31-2010, 01:05 AM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Re: cherokee will not take 4 wheel drive
Sounds like the linkage might be out of adjustment...also being a 90 you may well have the vacuum-disconnect front axle, which may not be engaging properly.
If you have this axle, there will be a relatively large vacuum motor strapped onto the passenger side of your front axle....even if your transfer case is working properly, if that vacuum motor isnt doing its thing, it wont work.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 01-01-2011, 03:17 PM
found a broke vacuum hose. it was the yellow one going to the front axle.fixed that and it fixed my problem it takes 4 wheel drive great now. thanks littlehoov.
Old 01-02-2011, 12:58 AM
LittleHoov's Avatar
Not a problem, glad you got it working. Did the part-time light go off?
Old 01-03-2011, 06:29 PM
yep , the light went off too. everthings working as it should. thanks again.
help gasguagedoes not work and will not take gas hardly!!!!! spflick Sable 0 07-13-2007 10:43 PM
95 JEEP GRAND CHEROKEE will not start Circuit Breaker Grand Cherokee | Grand Cherokee SRT8 8 10-26-2005 04:46 PM
1994 4.0 Cherokee Will Not Start! megeneration Cherokee 9 03-14-2005 09:54 AM
Jeep Cherokee will not turn over davidlo Grand Cherokee | Grand Cherokee SRT8 5 09-02-2004 01:04 AM
1990 Cherokee will not turn over MadCowz Cherokee 1 07-25-2004 12:41 PM
