Old 12-29-2010, 09:49 PM
stb100 stb100 is offline
Ignition Sticks When Key Turned to Start - '99
My daughter's '99 4Dr Sdn does this most times she starts it. When you put the key in the ignition and turn it to start, the ignition sticks momentarily. You must manually turn it slightly back to not grind the starter. The car starts up and runs fine except for this. On occasion, this "sticking" will reset the car's clock and the radio will be reset from FM to AM...(?)
I've shot it with WD40 but it's only a very short term fix.
Any help much appreciated.
Thanks
SteveInVA
Old 12-30-2010, 08:18 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
Re: Ignition Sticks When Key Turned to Start - '99
That's a problem with the ignition switch.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 12-31-2010, 12:52 PM
Thanks. Wondering if you could tell me more specifically what that involves and + or - how much $$ you think it costs.
Old 12-31-2010, 03:04 PM
You should have your ignition switch replaced. It's the switch that you activate with the ignition key to start and run the car. It's activated by the ignition cylinder. It costs 120$ included part and 1.5h of labor.
Old 01-01-2011, 04:35 PM
Thanks. I'll check with my mechanic Monday. The stickiness issue, I thought I could spray away. The resetting of clock and radio, not in my skillset.
Thanks again. Happy New Year.
Old 01-02-2011, 11:26 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Fixing the ignition switch will probably fix the radio and clock reset problem as well.
-Rod
Old 01-02-2011, 12:40 PM
plymouthsrock plymouthsrock is offline
If I remember correctly, the "switch" containing the electrical contacts is seperate from the cylinder, either one can be at fault, more likely the cylinder assembly. (at least it was in my case).
Old 01-02-2011, 03:46 PM
Originally Posted by plymouthsrock View Post
If I remember correctly, the "switch" containing the electrical contacts is seperate from the cylinder...
Of course.
Old 01-07-2011, 06:40 PM
Took it to my mechanic. He thought it might need to be replaced as you said. Mentioned same thing about separate components within the lockset too, but, he wound up shooting powdered graphite into it. Works so far, knock on wood. We'll see how long it lasts. Cost me $24...Getting a tube of graphite powder tomorrow.
2003 Alero will not start, only service engine light comes on with key turned to ACC DelbertJay Alero 2 02-20-2012 04:05 PM
Turn key and nothing. no dash lights or response from the key turn at all. grrrtyson Cherokee 3 04-26-2010 12:12 PM
Fan turns off when key turned off! hylic Ninety Eight 2 03-30-2007 10:56 PM
No ignition buzz when key is turned, wont start bobraff Metro 11 03-30-2005 08:13 AM
Ford F150 Pickup Squeels when key turned but won't start kottoman F Series 3 04-28-2004 07:17 PM
