Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 12-29-2010, 12:19 PM
bigchimi bigchimi is offline
o2 sensor
Hey everyone,
I have an 03 matrix, and I need to replace the after cat o2 sensor. I can not get the old sensor to loosen up. I have tried penetrating lubricant, heating it, used every tool I can think of to try to get leverage, and it just won't move.
Anybody got any ideas that I haven't tried? Any help would be greatly appreciated.
Old 12-29-2010, 02:54 PM
danielsatur danielsatur is offline
Re: o2 sensor
A local muffler shop!
Old 01-21-2011, 02:17 PM
malibu2 malibu2 is offline
Send a message via AIM to malibu2
Re: o2 sensor
you can get a socket from autozone that has the split down the side that wont screw up the wire. you can also rent it and when you take it back you get your money back for using it but i'd just buy it it's probably around $10.00 you'll need it later thats why i say just buy it.
Old 01-21-2011, 06:24 PM
Re: o2 sensor
Consider a recycle H02 sensor for down stream from a salvage yard!
Old 01-21-2011, 11:12 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: o2 sensor
Sometimes it is easier to remove when the whole exhaust is up to normal temperature...get the special slotted socket and a BIG breaker bar.
You can also take it one step further and spray some freeze rust breaker (just make sure it isn't flammable) onto the O2 sensor or even a high pressure air stream to quickly cool it, cause it to contract, and hopefully loosen it from the exhaust pipe thread.
I wouldn't buy a used O2 sensor...you don't know the condition of the car it came out of, so it could be on it's way out as well. Besides, it's a bitch to get out once, do you want to hack at it to replace it again so soon?
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 01-22-2011, 05:56 AM
snshddog snshddog is offline
Re: o2 sensor
I assume after this long you have it done but heres my 2 cents. Unless you are keeping the old sensor as a trophie or something then cut it short and use a regular socket. They are hard to cut but can be done. With it being this hard to get out don't forget to chase the threads.
Old 01-22-2011, 11:59 AM
Re: o2 sensor
I wouldn't use a recycled H02 sensor for the upstream pos, that signal is a feed back signal for the Air/fuel mix.
As far as using a used HO2 sensor down stream, it just tells the PCU/ECU, if the catalytic converter is doing it's job!
Don't forget to use Anti-seize compound.
I have no problem using recycled parts like EGR valves, O2 sensors, bulbs, fuse's, relays, engines, transmissions, and metal body parts.
Caution - Don't waste your time with old plastic, or rubber.
