Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-29-2010, 11:49 AM
Gagecase's Avatar
Gagecase Gagecase is offline
200 Rodeo trans again
I have a 2000 rodeo automatic trans. I have had the tranny rebuilt twice in less than a year for the same problem. If I drive on the highway or drive awhile, the truck will have trouble shifting in 2nd gear making a loud bang noise then check trans light comes on. After awhile of leaving truck parked it will drive fine until Im driving for awhile again. U know anything about this fellas.
What does limp mode mean? Is that when t he engine is running and the trans won't move truck? If so how do i get the truck out of limp mode?
Thanks for reading.
The truck is an automatic. v6 no 4 wheel drive.
Old 12-29-2010, 12:06 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 200 Rodeo trans again
do the shift indicators on the floor and the dash match up when you run it through the gears?
Many times the banging into gears is caused by a dirty or faulty transmission range selector (bolts on the side of the tranny). See the FAQs for more details.
The second reason it may bang through the gears is due to low tranny fluid. The engine needs to be running to properly top off the tranny fluid.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 12-29-2010, 05:05 PM
Gagecase's Avatar
Shift indicator matches up. Do u know any places who fill and check transmission fluids? Jiffy lube maybe walmart.
Can u tell me what limp mose means and how to get truck out of that?
Thanks for reading and reply.
Old 12-29-2010, 06:14 PM
Isuzu Guy
limp I think is just a reduced power mode.
To reset it, try undoing the battery for 30 minutes.
I would call Jiffy lube first. Most places won't touch isuzu tranny's because there is no dip stick.
-Ryan
Isuzu Moderator
Car Show Tips
Old 12-29-2010, 10:58 PM
Gagecase's Avatar
Thanks I still dont understand why Isuzu chose the dip stick for the tranny.
