Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 12-29-2010, 12:02 AM
jgmack823 jgmack823 is offline
Pinging in idle
I stopped at a stoplight and heard an unfamiliar pinging...
It seems like it is coming from the alternator.
It drives like a champ...(Maybe I shouldnt be driving?)
I was told it might be my valve sticking and the pushrod is just hitting it
Since it is not making noise when it drives the oil pressure is higher and it then moves the hydraulic valve....
IF it is my valve...
Take cover off and how do i find out which one it is... Do i have to change it can i just move it?
Now on my way home it was smoking a little bit...
I HAVE OIL
I HAVE ALL FLUIDS
Old 12-29-2010, 08:51 AM
Jrs3800 Jrs3800 is offline
Re: Pinging in idle
What year and how many miles?
The Following User Says Thank You to Jrs3800 For This Useful Post:
jgmack823 (02-19-2011)
Old 12-29-2010, 04:01 PM
Re: Pinging in idle
1990 SSE 131XXX
same dash lights as your pic
Old 12-29-2010, 04:07 PM
Re: Pinging in idle
Could you possibly get a video of this?
Old 12-29-2010, 05:42 PM
Re: Pinging in idle
It was cold, but you can hear the pinging, it is kind of hard to tell where its coming from.
http://tinypic.com/player.php?v=2w2knx2&s=7
Old 12-29-2010, 06:21 PM
Re: Pinging in idle
it is possible that snow was under the hood possible burning off.
Old 01-01-2011, 06:58 PM
ecartman ecartman is offline
Re: Pinging in idle
Check the harmonic balancer (crankshaft pulley). The pulley has a rubber damper that dries out and separates from the pulley causing excessive play and a noise very similar to the one in your video. Good Luck!
The Following User Says Thank You to ecartman For This Useful Post:
Old 01-05-2011, 03:59 PM
Re: Pinging in idle
I completely agree... Check the Crank Harmonic Balancer... Like stated the rubber can crack and break... The outer part of the balancer sits on a bearing so it can move to a certain degree with the AC Compressor turning on and off, the balancer absorbs this shock so that you don't feel it... What you are most likely hearing is the balancer hitting the stops..
Check it out and see if the rubber is cracked up...
Old 02-19-2011, 03:36 AM
Re: Pinging in idle
Its been a while since i been on here but exactly the problem....I don't know what I would have spent with this site but it would have been a lot more than 90 bucks
Running rough and loud pinging caffeineaholic Caprice 8 07-14-2010 09:49 PM
'96 Camry 4-cyl 2.2L Idle Control Sensor Maulana Camry/Camry Hybrid/Vista 4 03-18-2010 10:29 AM
93 Rodeo cranks but won't idle. Help! hansola Rodeo | Passport | MU 1 04-13-2009 08:00 PM
Rough Idle Mayathebee Cougar 1 03-22-2009 08:23 PM
92 Jimmy Dies When Idling rockavenger Problem Diagnosis 3 03-10-2009 09:52 AM
