Old 12-28-2010, 01:12 PM
cf1 cf1 is offline
spark plugs
i have an 2006 silverado 4.3 need to replace the plugs. anyone recomend .thanks
Old 12-28-2010, 04:40 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: spark plugs
AC delco PLUGS
Bosh and c4 and other brand are junk and do not work right in GM engines.
Always check the latest AC delco spark plug book for right plug and gap.
A lot of times the no and gap is changed from OEM plugs and gap.
How many mile on your plugs?
MT
Old 12-28-2010, 05:27 PM
ukrkoz's Avatar
ukrkoz ukrkoz is offline
Re: spark plugs
HALO spark plugs. one and only plug confirmed by government research to improve gas mileage.
they are pricey at around $8 a pop. so it's personal decision. i had them in my Silvie for around 60K miles w-out any issues, and changed just cuz they are warranted for 50K. not a sign of wear.
Old 12-28-2010, 08:19 PM
cf1 cf1 is offline
Re: spark plugs
Originally Posted by MT-2500 View Post
AC delco PLUGS
i got a 110,000 on the original plugs, i think its time to replace.
Old 12-29-2010, 06:21 AM
MT-2500's Avatar
AF - Advisor
Re: spark plugs
Hello Ukrkoz.
In my neck of the woods central USA Mark twain land.
I have never run across the Halo brand plugs.
Can you give a little more info on them.
Are they made by Halo or a branch of another brand?
Old or new company?
Do you order them or find local?
Are they Platinum or regular plugs?
Thanks MT-2500
MT
Old 12-29-2010, 06:30 AM
MT-2500's Avatar
AF - Advisor
Re: spark plugs
Yes for sure 110K is time for New plugs.
The life of a spark plug depend on a drivers habits.
Heavy foot tends to be harder on plug life.
Beside the better mileage after a set of new plugs.
Some engines if left in there to long the plug shell will rust up and or the threads stick in head letting or causing the plug to twist off in the head or plull head threads out with it or even some I have saw the gap burn up to very wide gap and throw a extra hots spark in the cylinder and burn hole in piston.
Good Luck and let us know how it goes.
MT
Old 12-29-2010, 09:37 AM
saturntech's Avatar
saturntech saturntech is offline
Re: spark plugs
8 bucks for plugs?? thats cheap
Old 12-29-2010, 09:59 AM
ukrkoz's Avatar
Re: spark plugs
Hello Ukrkoz.
Old or new company?
Thanks MT-2500
i have worked in the sticks Mark Twain part of the country for 19 mths, and that was the best car nuts land i have ever been to.
anyhow, HALo spark plug is made by Brisk. this company is prolly one of the oldest spark plug manufacturers in the world. they were originally stationed in Chech republic and started in 1928, i believe. They were, last time i checked, official plugs company for VW and Lambo racing teams.
HALo is a patented design, LGS Brisk. has full crown on the top. just like angels halo. bosch was trying to get close to it, but ended with open crown on the top, due to patent laws. they can't close crown completely, as this is Brisk design.
mine were made in Chech republic. they were, also, supposed to start manufacturing new series, with equivalent to iridium, as corrosion resistant metal.
Ontario government did full blown research on spark plugs, back in time, for their fleet of street cleaning vehicles. they had it statistically proven, that HALo improves mpg and Hp. not by much, but times thousands of vehicles and vehicle hours on the street, it added up. so no, it's not 10-20%. but it's there.
you can't buy HALOs in store. it's online only. i bought from that guy for several yrs. he's kosher to buy from.
well, now they say that HALOs are made in TX. who knows. maybe they are now. site looks quite different from what i was used to.
found them:
that's the original manufacturer.
ones i bought online here were 48 000 miles warranted. looks like they have platinum ones now.
1932. i was off by 4 yrs.
2001
• Supply of spark plugs to OEM Lamborghini Motori Marina
• Supply of spark plugs for small agricultural machinery to OEM SAGEM (JCAE)
• Supply of spark plugs to OEM AUTOVAZ
• Supply of spark plugs to OEM GAZ
• The company is ranked among the "CZECH 100 BEST"
2002
• Commencement of production of the second-generation BRISK Premium LGS spark plugs
• Supply of sensors to VW
2003
• ISO/TS 16949 certification
2004
• Extension of product range with BRISK IRIDIUM PREMIUM RACING spark plugs
• Supply of spark plugs to OEMs Renault-Dacia, GM, SEAT
• Supply of sensors to OEM VOLVO POWERTRAIN
http://www.brisk.biz/news.php?page=1
Old 12-29-2010, 11:10 AM
MT-2500's Avatar
AF - Advisor
Re: spark plugs
found them:
2001
2002
2003
2004
Thanks for the good info on them.
And web links.
That corrosion protection may be a very good deal.
I have had some plugs with shell rusted or ate threw and twisted off when you try-ed to change them.
The old fords with the larger plugs were a bear cat on that.
MT
Old 12-29-2010, 11:55 AM
ukrkoz's Avatar
Re: spark plugs
no, no, not that corrosion. electrodes corrode from the gap spark. that's why they continuously go for harder metals, less prone to arc corrosion. when arc corrodes metal off, gap increases. spark loses its power, due to ever increasing gap.
with HALOs, gap is causing one large ball of discharge. i could not see any major erosion on crown electrode after 60+K miles on them.
i am aware only of one better design in conventional plugs, Krupa plug, but he's an ass and never got it worked out into production. patented and it's on ice. patented any possible configurations, so it's untouchable.
there's a spark plug that pre-ignites fuel inside of it, and then shoots fire out into cc. not sure, how long will that work, considering how fast nozzle can get plugged with carbon deposits.
Old 12-29-2010, 12:15 PM
MT-2500's Avatar
AF - Advisor
Re: spark plugs
Thanks for the correction on corrision.
Looks like I got that mixed up.
Thanks for the info MT
MT
Old 12-30-2010, 10:40 PM
Elbert Elbert is offline
Re: spark plugs
GM vehicle = AC plugs.
All you have to do is get online, go to the autozone or advance auto web site, plug in your information and it will tell you the part # of the spark plug. Or go to the ROCK Auto web site.
AC plugs work.... don't waste your time with all the other magic potion stuff.
Elbert Clarke
Old 12-30-2010, 11:00 PM
cf1 cf1 is offline
Re: spark plugs
I went with origonal ac delco gaped at .60. one hell of a difference on take off.
Old 12-31-2010, 06:14 AM
MT-2500's Avatar
AF - Advisor
Re: spark plugs
Always check the latest AC-Delco spark plug book.
A lot of times the origional spark plugs no. and gap will be updated/changed.
Besides take off the MPG should come up to.
Thanks for posting back how it went.
Good Luck
MT
Old 12-31-2010, 04:57 PM
cf1 cf1 is offline
Re: spark plugs
Good Luck
well if i got 120,000 out of these delco, why not put the same number ac delco back in. im happy with the results.. thanks guys..
