Old 12-27-2010, 03:18 PM
rallycamaro rallycamaro is offline
98 blazer - no drive (long)
Hi all, new here and in need of some big-time help. Background: 98 blazer, 140k miles, 233 transfer case, backed out of the garage yesterday, put transmission into park to shift into 4Hi (10" of snow overnight), put transmission back into reverse and nothing, nada, put back into park and hit 2Hi to disengage 4WD and all transfer case lights went out, tried drive, 3, 2, 1 and R and none worked, put into park and grinding sound like a saw winding down ensued. Have disconnected battery to try to reset TCCM, no go, looked at encoder motor but see nothing out of the ordinary. Could this be a result of only vacuum switches and actuators? Don't think so but not sure. Bulbs on push-buttons flash on bulb check but go out after that. Nothing lights up, no clicks like trying to engage, nothing and have no drive. Is TC toast? Encoder out of phase or stuck between gears? Help.
TIA
Old 12-27-2010, 05:03 PM
old_master's Avatar
Advisor/Moderator
Re: 98 blazer - no drive (long)
Odd that a 233 would do that because there is no "neutral" in the transfer case but, it sounds like encoder motor trouble. Check the connector at the TCCM for corrosion on the pins and sockets. If that's OK, possibly the encoder motor or the connector at the encoder motor.
You have to know how it works,
to figure out why it doesn't.
Old 12-28-2010, 08:20 AM
Thanks, will do. Is it possible to manually move the transfer case into 2Hi so I can at least move the vehicle?
Old 12-28-2010, 12:17 PM
old_master's Avatar
Advisor/Moderator
You can remove the encoder motor and manually shift the transfer case, not a lot of room, but it can be done.
94 s10 blazer 4wd 4dr 4.3 parting out chevyshitsonford Classifieds 9 10-27-2016 09:35 PM
94 s10 blazer 4.3 high oil pressure chevyshitsonford Problem Diagnosis 4 03-08-2009 09:11 AM
PROBLEM now 98 blazer 4.3 v6 just replaced fuel pump smiley24 Problem Diagnosis 7 02-26-2009 10:45 AM
help my blazer driving me crazy c420lh Problem Diagnosis 1 12-08-2006 12:40 AM
'90 Blazer driving me crazy! Will not start. Butch Dennis Blazer 29 09-14-2004 12:35 PM
