Old 12-26-2010, 01:13 PM
sam95 sam95 is offline
96 lumina random misfire after repair
Had to replace lower intake on lumina reinstalled according to specs pushrods in order also new plugs and wires, when started car rough idle and random missfire code p0300 came up cant figure out what went wrong???
Old 12-26-2010, 02:16 PM
maxwedge maxwedge is offline
A990 racer
Re: 96 lumina random misfire after repair
Can you feel the misfire? Does it backfire on accell, all the plugs in the right order, no quick answer here go back over you connections.
Old 12-26-2010, 04:45 PM
can feel misfire at idle and also a slight popping from exhaust, also did a compression check on front cylinders range was 165 to 175 didnt check back cylinders yet. will go back and double check plug ins Thanks
Old 12-27-2010, 03:51 PM
Problem solved re-ran plug wires and 2 were crossed Thanks for the advice
