Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 12-26-2010, 12:22 PM
nikiml nikiml is offline
Montana 2005 - hard (up)shifts
This started on may car probably around 2 years ago, very infrequently (2-3 times a year), but recently it has escalated to happening on every trip when the engine warms up. The transmission starts up-shifting hard on every shift ( the first is the hardest). No problem lights are coming up. The problem goes away (temporarily) when the car is restarted.
How should I approach diagnosing this?
Are all the hard shift trouble codes reset on engine restart?
Are the transmission codes readable though the port under the steering wheel (sorry real newbie here) ? Or there is another port for those?
Thanks in advance.
nikiml
Old 12-26-2010, 08:04 PM
roadrunner2 roadrunner2 is offline
Re: Montana 2005 - hard (up)shifts
Harsh shifts in theses vans can be attributed to a worn low pressure solenoid in the tranny.
I had a harsh shift fault in a former 2000 Silouette and a filter and fluid change did the trick.
This is, however not always the case.
Normally trouble codes show up to 'steer' you in the right direction.
Personally, I'd take the van in and have a trans specialist check it out.
The problem with doing nothing is not knowing when you're finished.
Upgrade Rear (and front) Wiper Blades for Pontiac Montana dewaynep Montana/Montana SV6 2 06-03-2010 01:04 PM
MY 99 Montana won't rev past 3000 rpm's captainvoltage Montana/Montana SV6 0 01-18-2010 08:11 PM
1999 Montana won't start bat27 Montana/Montana SV6 1 07-06-2009 12:10 PM
Hard Starting 97 Riveria lavendorj Riviera 3 03-14-2009 08:52 PM
1999 montana transmission hard shift into overdrive bonga Montana/Montana SV6 5 11-03-2004 09:53 PM
