Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 12-25-2010, 11:43 AM
slicksystem slicksystem is offline
Exclamation CHALLENGING ALL MECHANICS to figure out this problem
Okay guys this is not going to be your simple fix kind of thread. I am a mechanic myself and i cant figure this out.
Problem: Car starts and runs rough (misfiring). Then after car warms up(5-10 min) it shuts off and wont restart until i let it sit overnight. Im running out of possibilities and i cant figure this thing out.also the car shutting off happened after letting the car sit for 2 months.two months later when i came back this problem was here. Im thinking it is a bad ecu.
car: 2000 toyota celica gts (automatic)
engine: 1.8L 2zzge (new re certified engine was recently put in)
1)new fuel pump
2)new thermostat
3)new coils and spark plugs
4)new MAF sensor
5)new water pump
6)new air filter
7)new coolant fluid
8)1 new oil pressure sensor of 2 total
9)new crank position sensor
10)new alternator
any answer you give me please also give me the way to test it. for example if you say it might be a bad iac sensor tell me how to test the sensor to see if it is good or not.
Old 12-25-2010, 01:43 PM
snshddog snshddog is offline
Re: CHALLENGING ALL MECHANICS to figure out this problem
A plugged up exhaust like a bad cat can do that. Had a corolla that acted like that with a bad cat. Loosten off the exhaust before the cat to see if it runs right as a test. A vacume guage addapted in the O2 sensor port can also tell you. Any pressure is bad. With a long stored vehicle I have seen a massive mouse nest in the muffler do it. Many other possibilities too. Keep us updated.
Old 12-27-2010, 03:20 PM
i have no cat i cut it off awhile back and put a o2 sensor simulator to take away the code.
im thinking its gotta be the ecu or the neutral safety switch, but idk how to test either of these and both are very epensive.
what do you think, or do you know of any ways to test these.
Old 12-28-2010, 03:45 PM
SCJake SCJake is offline
it does sound like it could be the ecu. honestly id go/call in to ur nearest junkyard/crazy rays and see if they got one. if they do its gonna be like 25 bucks. been there done that. tested it and it worked, so i bought a new one and kept the old one as an emergency. sounds like a pain in the ass, and it is, but its worth it if it fixes it
Old 12-30-2010, 10:24 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
The only other thing I can think of might be the engine coolant temp sensor. If it senses the wrong engine temp it will feed the wrong amount of fuel.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 02-21-2011, 03:19 AM
Coralie4grace Coralie4grace is offline
Smile Re: CHALLENGING ALL MECHANICS to figure out this problem
[quote=slicksystem;6851703]Okay guys this is not going to be your simple fix kind of thread. I am a mechanic myself and i cant figure this out.
1)new fuel pump
2)new thermostat
4)new MAF sensor
5)new water pump
6)new air filter
7)new coolant fluid
10)new alternator
Hi,
Sounds like a timing problem bro....
CG:
Old 02-21-2011, 03:43 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Has to be something temp related.
Either the ecu failing once it's warmed up, temp sensor failing, or an electronic part that fails when it's hot.
E.g. I had a problem with a prelude that would start when cold, but not run once warmed up. A small electronic bit in the dizzy had cracked, the crack expanded when it got hot and the car wouldn't run. Once it cooled down it would run again until it was warm.
Old 02-21-2011, 07:36 AM
Scrapper Scrapper is offline
AF Premium User
[quote=Coralie4grace;6873607]
1)new fuel pump
2)new thermostat
4)new MAF sensor
5)new water pump
6)new air filter
7)new coolant fluid
10)new alternator
Hi,
CG:
i never seen where you changed map sensor and are you getting gas and good blue spark all the time? have you done compresson test on all cylinders? i came accross a car that ran good until it set for awhile and it ran good pulled tank down and it was pluged inside tank on the screen and or sock.
Old 02-27-2012, 02:08 PM
mannasugar mannasugar is offline
When the car does not start: are you getting spark out of the coil/ plug wires?
Old 02-27-2012, 04:03 PM
jgabranski jgabranski is offline
Do you have a scan tool? If yes can it watch PID's? (can it see what the sensors are sending the ECU) My money is on the ECU. Sounds like as it warms it goes into closed loop "ECU controled" then drops the ball and stalls. That would also explain why it wont restart. Also, check and ECU relays and fuses for corrosion or defects.
Another thought, what is your fuel pressure look like at key on engine off and at idle?
HEEELLP!! CAnt FIgure Out this problem it might be electrical? Noystahz Let's get Technical! 0 06-03-2010 10:22 PM
Need to figure out this car PseudoKirby General Discussion 1 10-29-2006 06:23 PM
Am I the only one that can't figure out this motor mount? ozzfreak '88 - '91 Civic | CRX | Wagon | Shuttlee 5 01-19-2006 03:59 PM
Tags
car , celica , toyota , trouble
