Go Back   Automotive Forums Car Chat > Chevrolet > Lumina APV
Old 12-24-2010, 10:28 AM
RolandMD RolandMD is offline
Banned
Blower Motor - Only high
I know I have seen it on here before, but all I can find are threads that state "no high on blower motor." Mine is the exact opposite. All I have is high speed, with no low, mid, mid-high. Thoughts?
Thanks,
Roland
Old 12-25-2010, 03:38 AM
LMP's Avatar
LMP LMP is offline
Re: Blower Motor - Only high
I'd think the resistor pack is shot between B and A below
www.avigex.ca/xport/hvac_diagram_front.jpg
Pull it off and verify. www.avigex.ca/xport/heaterrelay.jpg
...but you had hi speed relay connector problems before...so consider this possibility, as even the lower speeds are fed through the high speed relay in released state...
...or for some reason, though improbable, the high speed relay does not fall back fully to its release position (to allow contact to all lower speeds). ThIs could be easily tested by pulling the relay out and installing a jumper wire from 87A to 30.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
1996 Explorer with blower motor issues CREESERFARM Explorer | Explorer Sport Trac 13 02-03-2011 01:13 PM
Taurus-2002 Blower motor only runs on high Hevehank Taurus | Taurus Wagon 2 08-05-2005 10:35 PM
Blower motor only works on high? BIGANT Premier 4 06-25-2005 12:00 PM
Blower Motor Only Works On High jakeismydoggie SC/SL/SW 4 12-02-2004 10:26 AM
