Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-23-2010, 08:42 PM
dynko dynko is offline
98 suburban tc issues
98 1500 5.7 stuck in 4L ,i can hear and feel it try to shift when commanded but can not make the shift.i have mitchel on demand and some pretty good flow charts so this is what iv got so far
switches test good
tccm tests good
correct power and ground at encoder
flow charts telling me to replace the atcm
removed encoder/motor and tried to shift case manually and its very difficult and i only seem to get two detents
seems like this should be easier to shift
am i way off here?
thanks in advance for any help
Old 12-24-2010, 05:53 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 98 suburban tc issues
switches test good
tccm tests good
am i way off here?
Is it throwing any codes?
Get out the volt/ohm meter and.
Go with the repair flow charts for that code.
Good luck and let us know hopw it goes.
MT
Old 12-24-2010, 10:11 AM
yea it is,sorry i forgot to tell you .C0327 encoder circuit fault
Old 12-24-2010, 12:04 PM
MT-2500's Avatar
AF - Advisor
Always check wiring and fuse and wiring plug-in.
Get out the volt/ohm meter and go all the way threw the repair flow chart for that code.
Good Luck and let us know how it goes
MT
Old 12-24-2010, 09:32 PM
(and tried to shift case manually and its very difficult and i only seem to get two detents
am i way off here?)
still would like to know if any one knows if this thing should shift easier or is this normal
Old 12-25-2010, 05:56 AM
MT-2500's Avatar
AF - Advisor
am i way off here?)
No way of telling without a hands on feel.
Kinda hard to do that over the PC boob tube.
How many lbs or ins of torque does it take to move shifter lever?
I would repair it per repair manual flow chart and see what it does.
Good Luck.
MT
01 2500 8.1 Suburban Fuel Gauge Issue aptivaa12 Suburban 2 08-25-2010 07:47 AM
Suburban Issue Throbbin Rods Suburban 0 05-30-2010 06:15 PM
1986 Suburban starter issues 1993Suburban Suburban 6 11-28-2009 10:21 AM
99 Suburban starting issue... smithguy Suburban 4 05-06-2009 08:48 PM
1996 Suburban Misfire when cold P0307 1993Suburban Suburban 5 02-23-2009 11:00 AM
