Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 12-23-2010, 03:07 PM
joeyd50 joeyd50 is offline
A/C on?????????
I just picked up a 1997 Ram 1500 5.9, Its real cold outside ( low 30's ) I wanted to see if the A/C worked, I turned it on but the comp. did not come on, could this be because its so cold outside?
Thanks
Joe
Old 12-24-2010, 06:59 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: A/C on?????????
Nope, the compressor should come on and cycle.
It's supposed to come on and cycle whenever the control is set on Defrost too to keep the compressor oil working throughout the system and help keep the seals in shape.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
