Old 12-23-2010, 01:06 PM
McLin's Avatar
McLin McLin is offline
Trouble with read troublecodes
Hi,
I have a ELM323 Scanner and it works 2 years ago fine.
Now I want to read freeze data because our 98 Lumina 3.8L get 15 Liters per 100 km.
But every time I read the freeze data I got diffrent values. But there must be a failure because the level from fuel and oil is jumping but I was in park position.
Did anybody the same symptoms? I think about fault ecm because the Lumina get never more then 11 Liters in City before 1 year.
Best regards McLin.
My Lumina
My Girlfriends Lumina
Mileage:
Old 12-23-2010, 05:57 PM
maxwedge maxwedge is offline
A990 racer
Re: Trouble with read troublecodes
I assume you are after fuel mileage increases, the gage readings are not part of this issue, correct? If so, look for fuel trims on your scanner long term will give you the most info, this time of year, in the nothern part of the US, it has not gone above freezing for 2 weeks, my 3800 Buick is down about 3 mpg. My engine is running well. I would suspect driving conditions, number one, maybe a tired o2 sensor number 2. There are no live fuel trim readings in freeze frame, don't use this mode to check live data such as fuel trims or 02 sensor activity.n Also does the engine reach 195 degrees fahrenheit in a reasonable warm up time?
Old 12-24-2010, 04:28 AM
McLin's Avatar
I don't think that the temperature here is the problem, because the higher milage began at begin this year.
I would read the Air / Fuel ratio and other relevant points, but every time I refresh the freeze data there are other values then before.
If the temperature outside cold like -10 degree celsius then there is knocking noise from the engine. It goes after 2-3 minutes. So my diagnosis was in the oil is too much fuel but without values from OBD Interface I don't know if the mixture are ok, or the sensors...
Best regards McLin.
My Lumina
Mileage:
Old 12-24-2010, 05:48 AM
A990 racer
Again, don't use freeze frame values, do a live data scan look at fuel trims, especially long term, freeze frame will tell what the data was when a code is set.
Old 12-24-2010, 12:32 PM
McLin's Avatar
Ok but with ScanXL I can read just rpm, speed, temp...
Which Software would zou use?
Best regards McLin.
My Lumina
Mileage:
Old 12-24-2010, 02:03 PM
A990 racer
I have an Actron 9145.
Old 01-01-2011, 07:59 AM
McLin's Avatar
Can anybody tell me what is the different between ELM 322 and 327? And can I use 327?
Happy new year!
Best regards McLin.
My Lumina
Mileage:
