Old 12-23-2010, 12:43 PM
wagslick wagslick is offline
Replacing encoder motor procedure
I've got a 99 Silverado 5.7 L and i'm replacing the 4wd encoder motor at the transfer case. I just can't seem to install the new one. I'm thinking I need to line up the male part pin on the transfer case with the female end on the encoder motor. How do I turn that pin on the transfer case so the two line up?
Old 12-23-2010, 04:02 PM
j cAT j cAT is offline
Re: Replacing encoder motor procedure
put the old encoder motor back in . using the 4wd switch place the transfercase to neutral . then try to install the new encoder.
THE NEW ENCODERS COME POSITIONED IN NEUTRAL.
IF THE OLD encoder is inop then jack up rear wheels off ground tranny in neutral , rotate drive shaft then try to rotate the transfercase slot.
the encoder motor has 2 heavy guage wires these go to the motor . if all above does not work, then using fused jumper wires carefully apply power to the encoder motor wires for a very short time 1/2 second ,as you watch the motor rotate .
connector C1 pin A is the blk wire, connector C1 pin B is the red wire. you can put positive on blk or red . this is how the motor reverses direction normally. doing this manually for a very short time you can safely rotate the encoder to the correct position..
after this is correctly aligned then install the gasket in position for permanent mounting.
connector C1 pins D and C are the locking feed to lock up the motor ,,don't mess with them !
connector C2 this is the feedback to tell controller where the transfercase motor is in its position............
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
