Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '06+ Civic
Old 12-23-2010, 08:48 AM
s10manfrommars s10manfrommars is offline
2006 Honda Civic 4 door windows flakey
I have 4 windows. 2 work fine. 1 works 50% of the time and 1 (the driver window) works about 25% of the time.
When they work they are fine. When they don't they dont work at all. Sometimes if I press the button ALOT they finally go up or down.
Any ideas on how hard this would be to fix or how much it would cost to fix?
Old 12-23-2010, 09:19 AM
Scrapper Scrapper is offline
AF Premium User
Re: 2006 Honda Civic 4 door windows flakey
you can take door panels off and lube them. another look in between doors when you open it look where the door meets the front fender and theres a rubber boot covering wires check and see if you can see wires broke if you find there not then door panels off and lubed. also the switch may be bad or worn out or a cable frayed.
scrapper.....
Old 12-23-2010, 10:43 AM
Is it hard to replace the switch? Also is there some time of switch solenoid?
What do you think it would cost me to take it to the dealer and have repaired?
Old 12-24-2010, 10:49 PM
BullShifter's Avatar
If you are having problems with more than one window chances are the master switch is bad. The master switch from Majestic Honda is cheaper than any dealer.- http://www.hondaautomotiveparts.com/...NT+DOOR+LINING If you are unsure or unable to test I highly recommend letting somebody diagnose it first before guessing. The dealer will charge you retail price for the switch + labor if that's the problem.
Old 01-04-2011, 01:17 PM
Copytech99 Copytech99 is offline
I would try some PM 1st. Clean the tracks top and bottom. Make sure the rubber inserts in the lower channels are properly in place and clean. Lube any exposed cables and the regulator with white grease.
How to take out a rear side window from a 96 honda civic Danthony_20 '96-'00 Civic 1 11-05-2009 10:38 PM
Flipsyde Announce 1st Ever US Tour: The 2006 Honda Civic Tour With ... - PR Newswire (press release) Automotive News Automotive News Desk 0 02-16-2006 06:50 PM
2006 Honda Civic and Ridgeline: Canadian Car and Truck of the Year - About - News & Issues Automotive News Automotive News Desk 0 02-16-2006 12:50 PM
2006 Honda Civic LX Road Test - Auto123 Automotive News Automotive News Desk 0 02-04-2006 04:30 AM
2006 Honda civic bighommie Forced Induction 23 01-14-2006 06:13 AM
