Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 12-23-2010, 06:49 AM
auto trainy auto trainy is offline
Increased idle speed
I recently had a front emission sensor replaced and since then the idle speed has increased slightly,should I be concerned?
Old 12-23-2010, 10:30 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: Increased idle speed
How much is slightly? Can you hook up a device to read the actual RPMs? I believe it should be around 900 in neutral and 600 in drive.
I have mine tuned for 800 in neutral and 650 in drive.
This can be caused by a sticking IAC valve, among other bad sensor data.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
