Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 12-22-2010, 04:47 PM
wayne g wayne g is offline
heater hoses
when you guys say reverse heater core hoses can you let them like that? or do you have to change them back around .and does this clean out core? thanks wayne its a 99 dodge 1500 5.2l
Old 12-28-2010, 10:18 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: heater hoses
Sorry for the delay Wayne.
I haven't found sediment in most vehicles unless some sort of stop leak compound has been added, which you really don't want to disturb until you're ready to replace the heater core.
Some folks have had some success switching the coolant hoses to reverse flow and possibly dislodge sediment.
At your own risk, another trick is kinda risky because these heater cores are not built very sturdy.
Disconnect both heater hoses from the engine, connect a garden hose to one heater hose, turn on a little water and flush sediment out. Do not restrict the other hose in any way or you risk blowing out the heater core.
Low pressure air/10psi with some water poured into the line you're gonna shoot air into will dislodge sediment too.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
