Old 05-23-2003, 12:24 PM
DSM-Mark's Avatar
DSM-Mark DSM-Mark is offline
Questions: Castrol Super Clean (CSC)
This has probably all been discussed, but I can't find it. So, I'll ask some questions here, and hopefully this can be a good starting point for anybody wanting to use CSC to strip paint.
1: Do you dilute the CSC to strip paint?
2: What types of paint will it strip? ie, will it strip:
-enamels (Testors bottle, etc)
-acrylics (Tamiya acrylic, etc)
-lacquers (Tamiya's TS line, etc)
-automotive paints
How long does it take to strip each?
3: Has anybody ever melted/warped plastic by leaving it in a CSC bath for too long?
Any other questions, ask here! This thread is devoted to CSC!
Thanks, guys.
I work slowly!
Old 05-23-2003, 12:29 PM
TheSyndicate's Avatar
TheSyndicate TheSyndicate is offline
Don't dilute it. Full strength strips in less time.
It WILL strip lacquers, but not very well. Brake Fluid (DOT3) is better for stripping lacquers. It will definitely remove any kind of enamels because the chemicals in CSC are degreasers. Acrylics are usually somewhat difficult to remove with any product, but will remove with csc.
Old 05-23-2003, 12:39 PM
cartuner's Avatar
cartuner cartuner is offline
Now this i can answer for you
#1. no you don't need to dilute it just pour it into a bucket and toss in the model.
#2 answer = enamels, acrylics, laquers(what i do for these is take a piece of sand paper and really screw up the paint so you can see the primer under it and the CSC will eat the primer allowing the laquer paint to be brushed right off. of yeah it eats flesh so wear gloves and a work shirt or a junky old t-shirt and if you feel so inclinded to wear googles to protect your eyes from splashes then go for it. better safe then sorry
#2b answer depends on how much paint there is on the part you are striping and how long it has been on the part/body. best soild answer i can give you is toss the model in and check on it every couple of hours or so until the piant starts to come off. it will also depend on the type of paint different paints take different times to strip off.
#3 my answer "No" i have never felt i needed to soak a part or body for that long of a time. all i can say is try not to get your self in to a place like that if you have a body/part soaking and you are going to be going out for such a long time just take the part/bodys out of the CSC and when you get home just toss them right back in.
Hope this helps you.
Old 05-23-2003, 12:46 PM
BaNe BaNe is offline
As already stated dont dilute it. You can use it several times before you throw it out. It will strip everything even "chrome" parts.
Name is Luke.
Faster and Faster until the thrill of speed overcomes the fear of death.
CompletelyStock except 17 Enkei RS6, Megan racing Downpipe-3" piping-megan racing muffler. no cat. K&N filter.
Old 05-23-2003, 01:11 PM
Jay! Jay! is offline
Horizontally Opposed
2. I've had some trouble stripping Lacquers with CSC. It's been a bitch to get certain TS sprays, Tamiya primer and Gunze spray lacquer off with CSC...
Hierarchy of Subaru:
(Click to see mine!)
Old 05-23-2003, 02:47 PM
008's Avatar
008 008 is offline
I've had a body in my CSC box for over a year. It was fine when I finally had to take it out to put another body in it. I didn't even empty the box and it strips just as well even with multi-colored paint particles floating around in there.
Soak it as long as you can wait, the longer the better. Get an old soft toothbrush, wear gloves and goggles, and scrub away while the car is in the bath. Don't try to wash/scrub the paint off under running water. Water will neutralize CSC.
It'll etch aluminum big time so don't splash it near aluminum parts (like your full-sized car's wheels) in your garage. You won't see it until the surface is ruined.
Do not soak resin parts in CSC unless you want them to do a disappearing act.
Scratch up the paint surface before dunking it to give the CSC little crevices it can seep into and work faster.
Old 05-23-2003, 05:59 PM
Mean_B16's Avatar
Mean_B16 Mean_B16 is offline
I have found the same results, I have had a hell of a time removing tamiya paint with CSC, oven cleaner will hopefully do the job.
Old 05-23-2003, 07:02 PM
For them, I've switched to DOT3 brake fluid...
Old 05-24-2003, 01:46 PM
Damnit! My Camaros primer didn't fully dissapear, so I decided to sand the sucker down, unfortunatly for the detail, most of it dissapeared...
AF MODELING FAQ
"Oh what a feeling.- Toyota
Old 05-24-2003, 03:48 PM
Mainomega Mainomega is offline
You can use ammonia...
It takes about 3 mins to eat all the paint. You can just leave it in a bucket and reuse it as needed. Doesn't melt plastic. BUT, dont breath it in or you'll loose some brain cells.
Got Something Good ? E-mail me
