Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 12-19-2010, 10:04 AM
dieseldevil1 dieseldevil1 is offline
Diesel Fuel Troubles
I have a 97' Dodge Ram 2500 w/ a 5.9 liter Cummins. I think I ran it out of fuel. After adding fuel I can't seem to get it primed up. I have already replaced the lift pump, but can't seem to get fuel up to the injector pump. Any help would be appreciated.
Old 12-20-2010, 07:07 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Diesel Fuel Troubles
Charge the batteries up real good, you're going to have to call on them.
I believe the lift pump has a button for manually pumping fuel to the injector pump.
It it feel like it's not pumping very deep, turn the engine over a half turn to get off the fuel pump lobe of the camshaft.
It helps if the fuel filter startts off full of fuel too.
You may have to loosen the fuel inlet connection to the injector pump to relieve the air.
If it pumps better with the front of the truck lower than the back, the fuel lines may be cracking and allowing air in.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 12-21-2010, 07:53 PM
Thank you for your help. As it turned out the first lift pump I bought was faulty, but the second one did the job.
Old 12-22-2010, 01:07 PM
Well the fuel problem is fixed, but as soon as I fixed that now I have a bad oil leak and I can't find it yet.
Old 12-22-2010, 06:13 PM
AF - Advisor
Good work on the lift pump.
Is it leaking at the front or rear of the engine?
Old 12-24-2010, 10:36 AM
It seems like it is leaking out of the rear main seal, but i'm suddenly losing about a gallon a day
Old 12-24-2010, 06:54 PM
AF - Advisor
That would be a huge puddle.
Is it leaking going down the road?
Old 12-27-2010, 05:20 PM
Yes because it is all over the frame rails, the fuel tank, trans, everywhere.
2000 Sonoma Replaced fuel pump ????????? cortervette Bravada 8 12-22-2010 10:42 AM
92 S10 W Blazer 4WD Fuel trouble LarryGLack Problem Diagnosis 15 04-04-2010 08:59 PM
