Old 12-18-2010, 07:38 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Stupid Question
2002 Taurus Sedan
Put back struts in this car about a month ago. It has recently deveolped a clunk that can be heard once in a while going over bumps on the rear passenger side. Everything is tight. The back stabilizer bushing on that side I did not replace and it seems the bushing has warn out allowing the stabilizer bar to have play on the shaft (I'm thinking causing this clunk).
So I got a couple new links. Moog brand.
Which way do the bushings go on the link shaft? (top picture or bottom picture). OEM ones came apart like the bottom picture so I'm inclined to put them in that way. But would rather do it once.
And these Moog links, is there a torque to set the torque wrench to when installing them? Or just snug them up?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 12-18-2010, 10:07 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Stupid Question
From the photos it looks like you have the bushings correct in both pictures. However, the cone washers in the top photo are the correct way to install them. There may be a torque spec somewhere for the aftermarket end links, but generally you tighten them so the rubber bushings just start to compress.
-Rod
Old 12-19-2010, 02:16 PM
tblake's Avatar
In God We Trust
Re: Stupid Question
Thanks Rod.
Thats the thing, I think they are poly bushings. I dont think I will be able to compress them unless I reef on them, and its only a grade 5 bolt.
I may go exchange them for the lesser expensive ones. These were the premium ones and were only 2.00 more. I may go exchange them for the regular rubber type.
Old 12-19-2010, 09:04 PM
shorod's Avatar
SHO No Mo
Re: Stupid Question
Even as poly you'll be able to see them compress. If not, the anti-sway bar wouldn't be able to move without breaking the bolt.
-Rod
Old 12-21-2010, 10:19 PM
stv840 stv840 is offline
Re: Stupid Question
They go together the way of the top picture a lot of techs just tighten them up with the air tool until they stop but this is a bit slopy and the part is less effective so after that tighten them up by hand until the bushings are snug the link shouldn't break as it's pretty durable also it is a one time install so don't worry about getting the bolts off again
