Old 12-18-2010, 09:59 AM
impressive1 impressive1 is offline
2001 f-450 abs/speedo issue
I have a 2001 f-450 with the v-10. A week or so ago the abs light came on for a couple of days then went out. The other day the light came back on and the speedometer started jumping all over the place while driving. The abs seems to be working properly. Could the two problems be related? Could it be a wheel speed sensor issue, if so where are the wheel speed sensors located?
Old 12-19-2010, 08:25 AM
big white bufflo big white bufflo is offline
Re: 2001 f-450 abs/speedo issue
the wheelspeed sensor is located on the top of the rear axle you will see it above the yoke these years have had troubles with this parts
Old 12-19-2010, 10:44 AM
Thanks Big White Bufflo. I hope that the two issues are a result of the one part (wheel speed sensor) Doesn't that sensor get it's signal from a gear that is bolted to the ring gear? I hope that the issue is not inside the housing.
02 Rendezvous - ABS/Traction Control Issue RGrizzzz Rendezvous 2 11-25-2009 04:04 PM
2001 mustang GT ABS issue bluesboyst Mustang Problem Diagnosis 0 10-27-2009 12:09 PM
2001 pontiac sunfire exhaust hanger issue liltricky00 General Discussions 0 02-12-2009 10:49 PM
2001 E 450 7.3l has a dead spot brbjim E Series 0 11-14-2006 02:43 PM
p12 primera abs/speedo not working!!?? pleeeeease help! desperatedan General Discussion 1 08-16-2006 10:09 AM
