Old 12-17-2010, 11:33 AM
mptc mptc is offline
2008 Trailblazer StabiliTrak System...
The StabiliTrak Indicator Light and StabiliTrak Service Light come on during startup which is normal, but occasionally they will come on a short time after I start driving the vehicle. It does not happen all the time and it seems to be more frequent in the cold weather.
Any idea if this is serious or not? I hooked up my code reader and it shows no codes.
Thank you in advance for your input.
Old 12-17-2010, 11:44 AM
maxwedge maxwedge is offline
A990 racer
Re: 2008 Trailblazer StabiliTrak System...
A std code reader cannot access that system, a high line professional scanner is needed. Something is wrong obviously.
Old 01-06-2011, 08:35 AM
tgwright tgwright is offline
I had exactly the same symptoms last week. I just had the dealer fix it under the warranty. They installed a new steering wheel position sensor.
Old 01-30-2011, 01:18 PM
Okay, I took the vehicle into the dealer service and they hooked it up to their scanner. No codes present or in history. They suspect a steering wheel position sensor is malfunctioning. With the scanner hooked up they turned the wheel from left to right but could not duplicate the code. They have seen this before on Trailblazers.
So my question...is this a do-it-yourself type of fix (replacement)? Is it an inexpensive fix?
mptc
Old 01-31-2011, 01:56 PM
A990 racer
What is the repair, with no definitive diagnosis what are you going to do?
Old 01-31-2011, 04:56 PM
I was thinking about replacing the Steering Wheel Position Sensor. The service department's analysis was that is is starting to fail.
Old 02-03-2011, 07:34 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
If they could not get any codes or it did not test bad then there is no way they can analysis or diagnost it.
First I would ask.
Was the testing done by a factory trained tech or the greese monkey or wash boy or floor sweeper?
If thet did not use a factory trained tech to check out it ask for your money back and find a dealer that has factory trained tech.
Did they check for any recalls or tsb's on the problem?
Throwing DIY repairs and parts at it is not usually a wise decission.
If they are sure it is the sensor let them replace with the under standing that if that does not fix it it is on there dime.
MT
Old 03-27-2015, 07:49 AM
tbuckit1's Avatar
tbuckit1 tbuckit1 is offline
Send a message via AIM to tbuckit1
Yeah, sure, that always works.
"What in the wide, wide world of sports is a go'in on here?" - Taggert
Old 01-29-2018, 11:51 PM
Update on this issue....Had the stablitrak and the traction control lights illuminate on the dash. It happens more in the fall and winter than in the summer, but I start the car and as I turn the wheel to back out of a parking space the 2 lights illuminate. I put a code reader on it and it stored the following codes.
C0196 Yaw rate circuit malfunction.
U1026 loss of Class 2 communication with ATC.
Is the YAW Rate and Lateral Acceleration Sensor an easy fix? According to the information I have it is under the front passenger seat.
mptc
Old 01-30-2018, 11:16 AM
A990 racer
Check this. https://www.yourmechanic.com/article...aw-rate-sensor
Old 01-30-2018, 01:17 PM
Yes I saw that website earlier. Both lights come on at the same time.
Any source you recommend for the YAW Rate Sensor.
Thanks!
mptc
Old 01-30-2018, 01:50 PM
A990 racer
I would suggest oe GM parts, for a safety related component.
Programming Key - 2008 Vibe Trekkie78 General Discussion 0 12-23-2009 06:55 PM
1995 325i Cooling system overheating troubleshooting kennethwperry 3 Series 0 09-20-2009 07:32 PM
Announcement of TOYOTA(Guangzhou) on Camry's braking system defect ChinaCamryUser Camry/Camry Hybrid/Vista 3 04-27-2009 11:54 PM
CAN (controller area network) or FlexRay systems? rnelson3 Engineering/ Technical 0 04-24-2009 10:27 AM
