Old 12-16-2010, 10:27 PM
CL8 CL8 is offline
An Answer For Negative Grounding Of Vehicles
There has been a lot of discussion on negative vs. positive grounding of vehicles here including a thread I started a while back.
The reason given for negative grounding was to standardize grounding in vehicles.
http://www.automotiveforums.com/vbul...tive+grounding
Today I came across this article with this bit of information about WHY they chose negative vs. positive grounding:
Why Are Vehicles Negatively Grounded? The best explanation to this question comes from a 1978 Rolls-Royce Enthusiasts' Club service manual.
"...it has been found that cars wired positive earth [ground] tend to suffer from chassis and body corrosion more readily than those wired negative earth. The reason is perfectly simple, since metallic corrosion is an electrolytic process where the anode or positive electrode corrodes sacrificially to the cathode. The phenomenon is made use of in the "Cathodic Protection" of steel-hulled ships and underground pipelines where a less 'noble' or more electro-negative metal such as magnesium or aluminum is allowed to corrode sacrificially to the steel thus inhibiting its corrosion."...
http://jgdarden.com/batteryfaq/carfaq2.htm
So the reason they chose negative grounding was to lessen corrosion on the body of the vehicle.
Any comments and confirmation appreciated. I found this very interesting.
That if thou shalt confess with thy mouth the Lord Jesus,
and shalt believe in thine heart that God hath raised him from the dead,
thou shalt be saved.
For with the heart man believeth unto righteousness;
and with the mouth confession is made unto salvation.
Romans 10:9-10
Old 12-17-2010, 08:22 AM
maxwedge maxwedge is offline
A990 racer
Re: An Answer For Negative Grounding Of Vehicles
Yikes, every car/truck here in upstate NY is rusted badly after 10 years. My 55 Chrysler is not, as a 6v pos. gd car. But it has not been in the sno/rain for 25 years. LOL Sounds good in theory, but I think there is more to this I am sure a thorough Google search would reveal more info.
Old 12-18-2010, 01:23 AM
CL8 CL8 is offline
Hi Max!
As you pointed out, other New Yorkers keep their cars out in the elements and your 55 Chrysler is kept protected in the garage.
All things need to be equal for a fair comparison.
I did a little more research and came up with this from an Australian Rolls Royce club site:
The RR Service Sheets dated 1960 detail the problems of radiators being choked by silt (mostly iron oxide from the block) being deposited by electrolytic action. A system of braided bonding straps was developed from the generator to the radiator to try and reduce this problem and finally the generator was electrically insulated. The cause of these problems was, of course, the positive frame so that is why the company changed polarity to negative frame.
http://www.rroc.org.au/wiki/index.ph...nical:Polarity
I am trying to find a link to the RR service sheets, but haven't found them yet.
It seems to me there is some truth to this no matter how minor the effect might be.
Even if positive polarity didn't cause a noticeable increase in corrosion, it appears manufacturers believed it did, and thus impacted their decision to change to negative grounding.
Romans 10:9-10
Cant find the ground on my 91 Toyota pick up KelevraGreywolfe88 Pick-Up 7 12-30-2010 08:09 PM
Ground for fuse block?? lugnutz24 Suburban 2 03-01-2010 06:29 PM
1996 Suburban air bag system ground 1993Suburban Suburban 1 07-05-2009 08:50 AM
FOR SALE!!! GROUND CONTROL ADJUSTABLE COILOVERS & TOKIKO SHOCKS AND STRUTS NeMax97 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 05-12-2005 02:35 PM
Looking for Diagnosis software for OBD-I vehicle arejones C/K 0 02-17-2004 05:34 PM
